76
[UNIFIED]OnePlus 9 pro Battery, heating and charging feedback thread
  1. OAJJAIN
    Eclair Apr 19, 2021
  2. Anurag Nandi
    Cupcake Apr 19, 2021
    Anurag Nandi , Apr 19, 2021 :
    After installing the new update, phone is still warm and battery status on DevCheck shows overheat (temp - 40 deg C). Anyone else facing the same issue? Looks like this is going to be a recurring problem going forward 🙁
  3. Swejuggalo
    OnePlus 9 Series Expert Community Expert Apr 19, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Apr 19, 2021 :
    The overheat warning is still false though. Toggle reverse charging on/off if you own a 9 Pro.
  4. viper134 likes this.
  5. MythicalAnimal , via OnePlus 9 Pro Pine Green , Apr 20, 2021 :
    My battery life was good in previous update also and after this one it's same as of now getting 7.5hr of SOT.
    For heating I didn't faced any overheat till now.
    addy_mufc likes this.
  6. CS1989
    Honeycomb Apr 20, 2021
    CS1989 , Apr 20, 2021 :
    Normal usage with social apps again. Camera clicks.. it get warm and around 42© .. no game. At restaurants normal fan ambient... Hmm.. so it fix or not. ? 🤔🤔🤔🤔
  7. Anurag Nandi
    Cupcake Apr 20, 2021
    Anurag Nandi , Apr 20, 2021 :
    Phone appears to overheat more after the recent update. I am not able to use apps like FB/IG/Whatsapp after 5 mins. It feels warm even when not in active use. I am sitting inside an air-conditioned room at 24 degrees. Attaching the screenshot from Devcheck. OP team please help.
  8. aakashsood
    Jelly Bean Apr 20, 2021
    aakashsood , via OnePlus 9 Pro , Apr 20, 2021 :
    No. Still overheating while charging and normal usage.
    xuguo07 likes this.
  9. aakashsood
    When do you face the heating issue? I've seen people stating different scenarios like only while gaming or not facing heating issue at all. I face it almost all the time while using. Only time the phone is at room temperature is when it is not being used. The latest update did address the battery drain issue for me though.
  10. Swejuggalo
    OnePlus 9 Series Expert Community Expert Apr 20, 2021
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Apr 20, 2021 :
    No extreme heat but perhaps not great either.
    After an update the system may need some time before it works optimally.
    If your activity on the phone always jumps up and down like that and never seems to be more calm there might a few background activities causing some workload. Can be perfectly normal but will cause additional heat and drain. A flatter line means less heat. Perhaps it calms down after a charge cycle or 2.
  11. R2rB_ski
    Froyo Apr 20, 2021
    R2rB_ski , Apr 20, 2021 :
    That's an excellent score 7.5h SoT. I got only 4h to 5h max. My previous phone was about 7 to 8 hours on average SoT. (P30Pro)
    satyam.guptaa likes this.
  12. Rajath009
    Rajath009 , via OnePlus 9 Pro , Apr 20, 2021 :
    Hey I am using OnePlus 9 pro since 5 days and I have faced lot of battery drains even if I am not using the phone too much...my previous phone was OnePlus 7 pro lasts longer than my 9 pro with 4000 MAH battery....please try to fix this issue because battery drain is major issue in this phone...
  13. Swejuggalo
  14. viki95037
    Donut Apr 21, 2021
    viki95037 , Apr 21, 2021 :
    What is the on average one plus 9 pro screen time? I am getting 5-6 hrs max in one cycle and not more than that. and what should I do to increase my screen time.
    Viplax1000 likes this.
  15. Nipu_1998
    The Lab Reviewer - OnePlus Nord 2 Apr 21, 2021
  16. Funk Wizard
    Moderator Moderator Apr 21, 2021
  17. dinamoski
    Honeycomb Apr 21, 2021
    junito91 and iangelrice like this.
