30
[UNIFIED] OnePlus 9R Battery, heating and charging feedback thread via OnePlus 6T
  1. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 22, 2021
    Caomhin , via OnePlus 6T , Apr 22, 2021 :
    Please use this thread for any questions, SOT, tips, issues, and all things related to battery, heating, and charging of the OnePlus 9R.
    Please note that the way you use the phone (daily usage scenarios and habits) will make a huge difference to the battery/heating performance. In a scenario where there is a heavy performance workload, such as photo shooting/video shooting/mobile gaming/video consumption, the power consumption and heating of the phone will increase accordingly, which is a normal phenomenon.
    There are also many other factors that can affect battery and heat, even ambient air temperatures above 25°c+ can slow down charging or cause heat issues, as the air temperature gets hotter the phone cannot dissipate heat as quickly so may even slow the charging down as a safety measure as well.
    You are more than welcome to share any battery and charging tips and tricks in the comment section and ask a forum moderator to pin your post on the first page of this thread.
    Also, please do check the links below for suggestions on alleviating any battery, heat and charging issues. Along with more details on improving your experience with the OnePlus 9R.
    Here are some tips to Optimise the use of your phone. This may help with many phone issues:
    Battery optimization never ends. To help OnePlus better resolve battery/heating-related issues, please submit a bug report via the Feedback Tool in the Community app or https://forums.oneplus.com/feedback
    Thank you for your participation in improving the OnePlus experience.
    Gor., LambLeeg, Harini K and 27 others like this.
  2. I1619062251001
    Cupcake Apr 22, 2021
    I1619062251001 , via OnePlus 9R , Apr 22, 2021 :
    I got a new OnePlus 9R. I just started using the phone. I am facing battery drain and heating issue. A new phone shouldn't be throwing these issues. Could you please look into it ASAP and come up with an update?
  3. Caomhin
    Many suggestions to try in the posts linked, in the original post above.
    Sumeshplr6 and J1622100367187 like this.
  4. OnePlus Tester1
    Testing account Apr 23, 2021
    S1618932517638 likes this.
  5. ErVishal
    Cupcake Apr 23, 2021
    ErVishal , via OnePlus 9R , Apr 23, 2021 :
    I already done battery optimization upto far more extent but the way battery is draining, is not accepted at all in brand new phone....
  6. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 23, 2021
    Caomhin , via OnePlus 6T , Apr 23, 2021 :
    If you don't see any improvement after trying the suggestions given. Please send Bug reports and give Feedback on the issues back to the OnePlus OOS developers. So that they can investigate them. Thank you.
    Community App Feedback tool
  7. imzz_teli
  8. Vineetgarg90
    Cupcake Apr 24, 2021
    GovindAnurag and AaqibAhmad like this.
  9. Jswn_Grg_92 , via OnePlus 9R Carbon Black , Apr 24, 2021 :
    I've been using the new OnePlus 9R for almost a week & I have noticed few issues that needs to be sorted out.
    1. Phone is always feeling a little warm in hand even though I don't play any games on my phone.
    2. Phone heats up during charging
    3. Battery drain can be improved
    4. Split screen is simply not working.
  10. S1618932517638
  11. S1600063493635
    F_Anurag_Singh_Jadon_ likes this.
  12. Caomhin
    OnePlus 9 Series Expert Community Expert Apr 24, 2021
    Caomhin , via OnePlus 6T , Apr 24, 2021 :
    Reset the Mobile Network adapter to see if it can alleviate the issue.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
  13. Giz
    Eclair Apr 24, 2021
    Giz , Apr 24, 2021 :
    Since almost everybody on the internet who has bought the OnePlus 9R is facing heating and battery issues, it will be better if OnePlus does thorough testing on their side and releases an appropriate OTA update. Not everyone can take the effort of generating logs and uploading them.
    From what I can see, this seems to be an optimization issue from OnePlus's side; it's least dependent on the user or surroundings.
  14. L1610609105469 , via OnePlus Community App , Apr 24, 2021 :
    Is the heating issue on Oneplus 9R solved ?or we need to wait for being fixed. Is it a hardware problem or software can manage it ?
    Does everyone face the heating issue on normal usage ?
    Do you prefer 8T over 9R? or to wait for 9R to be fixed?
    #help_please
  15. Swejuggalo
  16. Akashmitra297
    Donut Apr 24, 2021
    Akashmitra297 , via OnePlus 9R , Apr 24, 2021 :
    Here it is battery ampere
    Im very disappointing with slow charging on one plus 9r u can see tem° is only 36° but charging speed is very slow at this time how can i fix this problem ??
  17. Swejuggalo
  18. pablofg1978
    Head Moderator Head Moderator Apr 24, 2021
    pablofg1978 , Apr 24, 2021 :
    Thread merged
  19. U1615093153440
    U1615093153440 , Apr 24, 2021 :
    Hey,
    I am also facing same issue . I am using stock charger.its usually taking 1hr 10 mins to charge from 15 to 100
  20. Swejuggalo
    Swejuggalo , via OnePlus 9 Pro Stellar Black , Apr 24, 2021 :
    A slower charge is usually the result of battery heat or high battery drain while charging.
    Is the battery hot for you?
    Can of course be a defect cable or charger too.
