30
[UNIFIED] OnePlus 9R Battery, heating and charging feedback thread
  1. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Aug 30, 2021
    Caomhin likes this.
  2. N1624212695510
    Cupcake Aug 30, 2021
    N1624212695510 , via OnePlus 9R , Aug 30, 2021 :
    I do not have this issue with my 9r. I handled calls when my batter was 11% still it depends on the signal strength the device needs to boost up. We're you in closed space while the call was received??
  3. Madhu88mohan , via OnePlus 9R Lake Blue , Aug 30, 2021 :
    I have also attended calls lower then 10% even, but that day ...it just switched off...that to twice ....
  4. Does!Compute
    KitKat Aug 30, 2021
    Does!Compute , Aug 30, 2021 :
    Try recalibrating your battery then
    Dresa91 likes this.
  5. ardicli2000
    Gingerbread Aug 30, 2021
    ardicli2000 , via OnePlus 9R , Aug 30, 2021 :
    Turn off optimized charging and use original cable. Not every cable is capable of 65watt.
    Though i do not recommend so. Warp charge will kill your battery faster.
    Sheppards likes this.
  6. Sumitsai
  7. pablofg1978
    Head Moderator Head Moderator Aug 30, 2021
    pablofg1978 , Aug 30, 2021 :
    Thread merged
  8. N1624212695510
    Ok. That is strange.. maybe the recent phone dialer update has fixed it now .. have you updated your device.?
  9. pablofg1978
    Thread merged
    Dresa91 likes this.
  10. A1623656977126
  11. pablofg1978
    Thread merged
    Dresa91 likes this.
  12. 5star02707
    Ice Cream Sandwich Aug 30, 2021
  13. B1619622581505
  14. pablofg1978
    Thread merged
    Dresa91 likes this.
  15. hardikagarwal2001
  16. ManikandanT
    Donut Aug 31, 2021
    ManikandanT , via OnePlus 9R , Aug 31, 2021 :
    OnePlus 9R Battery Drain Quickly please Fix this issue. Full charge Battery backup will come maximum 6 to 6.30 hours only. Now i m charging 3 times per day. After Update then only i m facing this issue. Please fix ASAP.
  17. Dresa91
    User of the Year 2016; Most Active User 2020 Community Expert Aug 31, 2021
    Dresa91 , Aug 31, 2021 :
    Can you please tell me how other users are supposed to „fix ASAP“?
    Can you please share your battery and usage stats?
    Please read this threads:
    https://forums.oneplus.com/threads/battery-facts.995140/
    https://forums.oneplus.com/threads/updated-2021-no-more-lags-freezes-battery-drain-heating.1415175/
    and
    https://forums.oneplus.com/threads/battery-analysis-and-battery-drain-trouble-solving.1413430/
    Caomhin likes this.
  18. Akshat Sehgal
    Ice Cream Sandwich Aug 31, 2021
    Akshat Sehgal , via OnePlus 9R Lake Blue , Aug 31, 2021 :
    6-7 hours of SOT is what you're supposed to get. What was your SOT before the update? What's your refresh rate? Are you using dark mode? Have you installed any apps after the update? Are any apps behaving abnormally?
    Also, it's not healthy to use your phone for 18 hours a day buddy. You should definitely reduce your usage else it'll affect the longevity of your device and cause adverse effects on your health.
    Caomhin likes this.
  19. Dresa91
    SOT is a very bad indicator…it always depends on so many factors,…
    Akshat Sehgal and Caomhin like this.
  20. ManikandanT
    Donut Aug 31, 2021
    Before update my battery backup will come around 10 to 12 hours. Using 120hz and i didn't use darkmode and i charged just two times per day. After software update only i facing this issue. Even i didn't play high graphic games
    too
