30
[UNIFIED] OnePlus 9R Battery, heating and charging feedback thread
  1. G_plusone
    Nougat Sep 11, 2021
  2. Svazam
    Cupcake Sep 11, 2021
  3. Swejuggalo
    OnePlus 9 Series Expert Community Expert Sep 11, 2021
  4. pablofg1978
    Head Moderator Head Moderator Sep 11, 2021
    pablofg1978 , Sep 11, 2021 :
    Thread merged
  5. RajatHande
    RajatHande , via OnePlus 9R , Sep 11, 2021 :
    Sure
  6. BetaBot
    Jelly Bean Sep 12, 2021
    BetaBot , Sep 12, 2021 :
    If above doesn't work, test your charger with other socket and other OnePlus device too. Make sure not a charger issue
  7. BetaBot
    What's the normal outside temperature where you live? Is it too hot?
    Make sure you clear unnecessary apps running in the back ground and also turn off wifi bluetooth and map location whenever not using
  8. pablofg1978
    Head Moderator Head Moderator Sep 12, 2021
  9. pablofg1978
    pablofg1978 , Sep 12, 2021 :
    Thread merged
  10. B1619930455132
    Cupcake Sep 12, 2021
    B1619930455132 , via OnePlus 9R , Sep 12, 2021 :
    last two days heavy rain fall in my location.How can you tell if my phone is heating up because of the temperature outside?
  11. pablofg1978
  12. hanishgopi
    Gingerbread Sep 14, 2021
  13. RajatHande
    Cupcake Sep 14, 2021
  14. P1630135051923
    Cupcake Sep 16, 2021
  15. rhyd1am
    KitKat Community Expert Sep 16, 2021
    rhyd1am , Sep 16, 2021 :
    Hi, there could be a couple of reasons why warp charge may not be working for you.
    Firstly, I'm assuming that you're using the original cable and charging brick for your device. Check that there is no dust or debris in either end of the cable, the port of the phone and the charging brick.
    Secondly, try turning off "optimized charging" in the phones settings and see if that helps.
  16. Rishavbhardwaj05
    Cupcake Sep 17, 2021
    Rishavbhardwaj05 , via OnePlus 9R , Sep 17, 2021 :
    Battery problems are not solving from 2 months...... please fix the issue on OnePlus 9r please give a suitable update... battery draining in 4 hour in normal usuage like that social media and calling
  17. the_o2
    OnePlus 9 Series Expert Community Expert Sep 17, 2021
  18. pablofg1978
    Head Moderator Head Moderator Sep 17, 2021
    pablofg1978 , Sep 17, 2021 :
    Thread merged
  19. Y1578886483716
  20. Y1578886483716
