22
[UNIFIED]OnePlus NORD 2 Battery, heating and charging feedback thread
  1. B1630017653871
    Cupcake Oct 19, 2021
    B1630017653871 , Oct 19, 2021 :
    OnePlus launcher is killing my battery on oxygen OS 11.3 with my Nord 2. This has only started to happen recently, possibly since I did the latest update. Does anybody have this problem too? Any tips on what might fix it?
    Anginio likes this.
  2. Sanjit_96
    Cupcake Oct 20, 2021
  3. D1627447406172 , via OnePlus Nord 2 , Oct 22, 2021 :
    I was very hopeful with new update from one plus for Nord 2 but they still did not resolved the issue of less screen on time. I had raised bug report shared it with developer prior and it seems they do not want to value customers.
    Still describing what is the issue.
    4 to 4.5 hours of SOT(screen on time). Battery drain over night not resolved.
    SOT was good (5.30 to 6.30 hours) with A.9 update. But new updates(A.10 and A.11) kept worsening it.
    I am still hopeful that A.12 update might bring back 7 hours of SOT which was there in A.9 update.
  4. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Oct 22, 2021
    Liehjan , Oct 22, 2021 :
    SOT is a bad way to measure battery performance, because to get a accurate number you need to use the exactly same apps for the exactly same amount of time for both the tests.
  5. D1627447406172 , via OnePlus Nord 2 , Oct 22, 2021 :
    That's the reason I have not given exact number of hours I had shared a range and I am sharing that after performing such test for more than 20 to 25 times. I have around 20 to 25 screenshots of battery life where it says it's just around 4 to 5 hours now where as previously it was giving around 6.30 hours with A.9 Update.
  6. D1627447406172 , via OnePlus Nord 2 , Oct 22, 2021 :
    I hope you understood my point and try helping find a solution to increase SOT
  7. Liehjan
    I got your phone, I usually use SOT as a measurement too... You could take a look at this thread for tips to increase SOT.
    https://forums.oneplus.com/threads/...heating-and-charging-feedback-thread.1474614/
  8. D1627447406172 , via OnePlus Nord 2 , Oct 22, 2021 :
    Nord 2 Update DN2101_11_A.11
    SOT was good (5.30 to 6.30 hours) with A.9 update. But new updates ruined it.
    Anginio likes this.
  9. D1627447406172 , via OnePlus Nord 2 , Oct 22, 2021 :
    May I know where is the solution ? I had tried every other tip/method to increase battery life. But it's just 4 to 5 hours max. If you can help please do it through software update.
    Anginio likes this.
  10. pablofg1978
    Head Moderator Head Moderator Oct 22, 2021
    pablofg1978 , Oct 22, 2021 :
    Thread merged
  11. Last edited: Oct 23, 2021
    Anginio and Sylvebois like this.
  12. Souravkum511
    Cupcake Oct 23, 2021
    Souravkum511 , via OnePlus Nord 2 , Oct 23, 2021 :
    When it's on video call upper part is warm faster and call cut very shortly and when using camera just hate this issue .. mainly slove video call problem...on video call hard last for 10 minutes after that call will disconnected..
  13. pablofg1978
    Head Moderator Head Moderator Oct 23, 2021
    pablofg1978 , Oct 23, 2021 :
    Thread merged
  14. Souravkum511
    Anginio likes this.
  15. Kareni
    Cupcake Oct 24, 2021
    Kareni , via OnePlus Nord 2 , Oct 24, 2021 :
    Recently I bought a Nord 2 mobile. While using it, the battery is draining fast, more than usual. Though I'm not using it for gaming or other heavy applications, it is draining so fast.
    Please assist.
  16. pablofg1978
    Head Moderator Head Moderator Oct 24, 2021
    pablofg1978 , Oct 24, 2021 :
    Thread merged
    Also, introduce yourself section is not meant for this type of content
    Mr. BG likes this.
  17. Mr. BG
    Welcoming Expert, Community Hero 2020 Community Expert Oct 24, 2021
  18. chPartha
    Eclair Oct 25, 2021
  19. T1627062143320
    Cupcake Oct 25, 2021
    T1627062143320 , via OnePlus Nord 2 , Oct 25, 2021 :
    Hi all
    My OnePlus nord 2 is charging insanely slow, the charging sign keeps on switching between normal charging and warp charging. It's taking almost 3 hours for full charge.
    Please help
  20. Tvm sasank
    Cupcake Oct 28, 2021
    Tvm sasank , via OnePlus Nord 2 , Oct 28, 2021 :
    Please OnePlus team do something for the battery drain of the OnePlus nord 2 5g it is draining very fastly and not able to use for whole day.
    And I think only this nord 2 series is having battery issues and that's why it is being drained.
    Please take this seriously and work on it.
    Many other also seeing this same issue.
    Please work on it and find solution.
    Thank you.
