3
Unified Op2 heating issues thread
  1. Heisenberg_009
    Ice Cream Sandwich May 5, 2017
    Heisenberg_009 , May 5, 2017 :
    I am writing this answer for the nth time.
    Many applications perform background sync through the Android System. Check for any rogue apps that constantly phone home which doesn't let your phone hibernate.
    elanglois likes this.
  2. bcshiguemichi
    Eclair May 5, 2017
    bcshiguemichi , May 5, 2017 :
    it also happened to me it was a Google Play Service problem.
    The unbeatable solution is root, underclocking to 1200 (there is no difference in performance), greenify, naptime, e etc.
    let me know If you need the full step by step
  3. F_Satwik_Tejo_JRYH
    Cupcake May 5, 2017
    F_Satwik_Tejo_JRYH , May 5, 2017 :
    Can you let me know the steps. Thanks.
  4. elanglois
    Lollipop May 5, 2017
  5. mjoshi
    Gingerbread May 5, 2017
    mjoshi , May 5, 2017 :
    1. Delete unnecessary applications you do not use
    2. Clear Cache
    3. Recalibrate battery
    4. If none of those work then factory reset your phone.
  6. pjshivam14
    pjshivam14 , May 5, 2017 :
    Battery drain bug is there is GREAT OXYGEN OS WHICH GIVES MORE OXYGEN to bugs.
    tulip_bibs likes this.
  7. noquarter
    Lollipop May 6, 2017
    noquarter , May 6, 2017 :
    Heating issues threads merged
  8. heroka
    Donut May 7, 2017
  9. aijaz_shekh01
    Cupcake May 7, 2017
  10. G_Vamshi_Krishna_GOrc
    Froyo May 11, 2017
    G_Vamshi_Krishna_GOrc , May 11, 2017 :
    I really don't know whats d problem with dis op2... Battery drains when I keep it in my pocket... It evn takes 10 hours to
    charge n drains very fast.... It doesn't drain when I keep it outside my pocket.... Guys sm1 hav any answer for dis?
  11. Horsault
    Marshmallow Moderator May 11, 2017
  12. F_Sudhir_Pujari_wZAv
    Cupcake May 11, 2017
  13. Yash Bhardwaj
    Jelly Bean May 11, 2017
  14. SaiRamGarimella
    Honeycomb May 11, 2017
  15. Anil Thomas
    Gingerbread May 11, 2017
    Anil Thomas , May 11, 2017 :
    In pocket the fingerprint scanner regular try to authenticate and gets fail every time this make the phone heat and drain the battery very fast. I tried by keeping pocket mode on but it is not working at all. so keep the phone screen side up or use flip cover. Keep the data connection off while traveling.
  16. G_Mohamed_Jasir_KLKQ
  17. youbi
    Portuguese POC Assistant Head Moderator May 11, 2017
    youbi , May 11, 2017 :
    Threads about heating issues merged.
    From now on this thread will be used to discuss possible heating issues on the op2. All new threads about this will be merged into this one.
    Please be aware that all smartphones heat up on heavy use, if you have used smartphones for some time now you will for sure have noticed that. :p :D
    If the temperatures remain around the standard values there's is nothing to worry about it. If the phone also heats up during standby time, then probably you have some "rogue" app that is using the soc power when it shouldn't, please check your battery consumption per app and you will probably find the app to blame.
    I also edited the first post with this info.
    noquarter and script like this.
  18. G_Shail_Shah_pXLs
  19. G_Vamshi_Krishna_GOrc
    Froyo May 11, 2017
    I don't think network would be problem here
    ... Coz it has nothing 2 do with battery heating
  20. G_Vamshi_Krishna_GOrc
    Froyo May 11, 2017
