9
Unified OP3/3T Battery Thread
  1. G_Steven_oOCJ
    Gingerbread Oct 20, 2016
    G_Steven_oOCJ , Oct 20, 2016 :
    Moderator edit by @Funk Wizard
    Please read about Battery Calibration below and Follow the steps for better battery life on the below thread:
    https://forums.oneplus.net/threads/...ting-tips-how-to-improve-battery-life.556988/
    Moderator edit by @pablofg1978
    Please use this thread to share or comment your battery issues and stats, DO NOT OPEN ANOTHER THREAD.
    You can also chech this thread for battery/heating tips
    https://forums.oneplus.net/threads/op3-3t-battery-and-heating-tips-nougat-oreo.542075/
    Hey guys , i usually unplug my phone at 100% and i notice something weird about the battery. It would drop to 97% after sometime without me even using it and it would stay at 97% for some good amount of time.
    Thanks in advance.
    Steven.
  2. keertivaibhav
    Froyo Nov 22, 2017
    Stickied Post
    keertivaibhav , Nov 22, 2017 :
    hi everyone....i m sure many of us are facing issues regarding "mobile standby" battery consumption whether in beta or in stable OS version.i searched the forum and found that its a bug.here i did something that worked for me....currently in beta 27 for OP3.
    1.Dial *#*#4636#*#* in dialer.
    2.U will get "phone information" option.
    3. In that u will find "mobile radio power
    " toggle button.
    4. It must be ON.Now turn that off and wait for sometime ,may be 1 min.Than it will automatically gets ON.
    5. Once it shows ON,reboot ur handset from that page only.
    Thats all worked for me and the mobile stand by was gone from battery statistics
    here are some screenshots.....good luck
  3. insomniachou
    Honeycomb Nov 25, 2017
    Stickied Post
    insomniachou , Nov 25, 2017 :
    Hi
    After a lot of online searching, I finally found a way to solve the issue that comes after updating to Oreo. Steps are listed below.
    1. Open the dialer and enter *#*#4636#*#*
    2. Click phone information.
    3. Find set preferred network type, choose the one that suits you. I am on AT&T, so I choose LTE/WCDMA, it was TD-SCDMA before I changed it.
    4. Reboot the phone and you're good to go. I have attached my battery status below.
    Note that after the fix I don't feel any battery life boost, only the cell standby doesn't show absurdly high. I was having decent battery life even when the issue was there.
    I edited this post on my phone, thanks and happy holiday
    Joe
  4. INDIANTROID
    Q1583570057560 and pratikghadi22 like this.
  5. savvymatthew
    Wahoux likes this.
  6. Mobile Fan
    Froyo Oct 20, 2016
    Mobile Fan , Oct 20, 2016 :
    I'm using CB 3.5.4 without any 3rd party apps installed. Battery drains approx 10% overnight or without any use.
    T1562643909378 and pratikghadi22 like this.
  7. G_Steven_oOCJ
    around half an hour or less.
  8. G_Steven_oOCJ
    i'm on oxygen os 3.2.6 , what about you ?
    L1588488638040 likes this.
  9. rmprakash
  10. zeus.01.01.01.01
    Lollipop Oct 20, 2016
    zeus.01.01.01.01 , Oct 20, 2016 :
    Must be due to some background apps or process running in the background ... Monitor ur battery drainage carefully
  11. G_Steven_oOCJ
    when the battery drop to 97% , i head into the settings to see what is using up the battery and there is nothing that is using up the battery.
  12. Deepak.Si
    KitKat Oct 20, 2016
    Deepak.Si , Oct 20, 2016 :
    Don't worry.....3% is not that much...It happens with mine too [​IMG]
  13. G_Steven_oOCJ
    6 hour sleep only drain about 0-5 % , how can a fully charge phone drain 3% in less then half an hour without even using. btw my phone is only 1 month old.
    Deepak.Si likes this.
  14. Robson
    KitKat Oct 20, 2016
    Robson , Oct 20, 2016 :
    Calibrate your battery perhaps? Personally I wouldn't care much.
  15. Deepak.Si
    KitKat Oct 20, 2016
    During sleep you are not engaging with the phone so Doze* does it's work & prevents the phone using much battery by limiting the process in the Background.
    But in the day the phone is in use much more then night like Moving with you so Gyro sensor is in work,Signal Drops depends on your changing location Etc.
    Doze..
    Make sure to turn Off the things like WiFi,Bluetooth,GPS when not in use to prevent searching and using more Battery...If you already not.
  16. G_Steven_oOCJ
    well , thanks for the information tho.
    Just one more thing , if the phone is fully charge and i leave it plug in , compare to a phone that i unplug when it reached 100% , will the phone that is plug in last longer than the other , like the battery drain slower ?
    I try doing both the one that is plug in after it reached 100% seems too drain battery slower. Any idea why ?
  17. robogo
    Honeycomb Oct 20, 2016
    robogo , Oct 20, 2016 :
    Sounds like a visual bug, nothing else. Try using an app like GSAM or BetterBatteryStats for more detailef battery usage info.
  18. Deepak.Si
    KitKat Oct 20, 2016
    It's not good for the Battery when you keep plugged in after 100%...nowadays most phones stops charging after 100% so some additional time is OK (only when you forgot to unplug) but not always.
    Please refer to this Link for more Information :- http://www.sciencealert.com/here-is-the-best-way-to-charge-your-phone
    Battery drain is much more talked issue....
    Some cause pop up eventually and gets fixed too .
    Read some more here too
    https://www.androidpit.com/battery-problems-and-solutions-android
    ..and keep your all apps updated mainly like Google Play services.
  19. INDIANTROID
    Gingerbread Oct 23, 2016
  20. Reaper@...01
    Cupcake Oct 28, 2016
    Reaper@...01 , Oct 28, 2016 :
    I am having the same issue from last three days.. and I talked to customer service, they told me to reboot the phone with volume down key button+Power button--> wipe cache and data-->wipe cache. Still the problem remains the same. Then I checked the battery option in Setting menu..and the issue was MEDIASERVER which sucked 42% of my battery in just 1.5 hrs. Did you check this issue in your battery? And if you find it Please help me to resolve the same.
  21. G_Steven_oOCJ
    Gingerbread Oct 28, 2016
    G_Steven_oOCJ , Oct 28, 2016 :
    when my battery drop to 97% , nothing show up at the battery settings.
  22. tcbernardchu
    tcbernardchu , Oct 28, 2016 :
    Likely working as intended. The battery is never actually charged to 100% because doing that would damage it, instead software is programmed to show it charged up to 100% and then pretend to drop to prevent people wondering why their phone can't charge past 97%.
    Sias1234 likes this.
