6
Unified OP3/3T Battery Thread
  1. jatinkalra07
    Gingerbread Dec 28, 2016
  2. mannulko
    mannulko , Dec 28, 2016 :
    how to lock oneplus 3t to particular lte band?i want to lock my jio 4g to band 5(850mhz) for better signal strength.PLS HELP
  3. mwolf93
    Cupcake Dec 28, 2016
    mwolf93 , Dec 28, 2016 :
    heavy battery drain due to enabled Bluetooth. And I didn't even used it actively.
    My OP3T consumes more or the same battery when I am not using it as if I do.
    Please fix this ASAP
  4. gearam balaji
    Donut Dec 28, 2016
    gearam balaji , Dec 28, 2016 :
    I bought my OnePlus 3t last week and after the oxygen 3.5.8 update my battery drains so fast what should I do??..
    Marcellofattoruso likes this.
  5. Bartnl
    Lollipop Dec 28, 2016
    Bartnl , Dec 28, 2016 :
    3.5.8 update?? There is no such update for the 3T.
    And normally it takes a couple of days for the battery to settle again
  6. niyu26
  7. FajthNoMore
    gandralakiran likes this.
  8. gandralakiran
  9. arpitvkarma
    Honeycomb Dec 28, 2016
  10. vinshu1596
  11. sneakerspark
    sneakerspark , Dec 28, 2016 :
    not feeling anything here. this is a brand new device on its first discharging cycle. setup the phone from fresh on latest version of OOS.
  12. shubham1497
    shubham1497 , Dec 28, 2016 :
    Enable the doze mode from developer options
    It will surely help you i had the same issue.
    You can also see running services in developer options and see if any process is running unnecessarily you can uninstall that app.
  13. shubham1497
  14. shubham1497
  15. shubham1497
  16. torgehansen11
    torgehansen11 , Dec 28, 2016 :
    Same here... Battery drains so fast.. doesnt even last one day... Hope it gets fixed in the new oxygenOS!
  17. F_Mahaveer_Vinaykiya_uMp
  18. airiartev
    Jelly Bean Dec 28, 2016
    airiartev , Dec 28, 2016 :
    youtube is using a lot of CPU on the backround, check it in settings, apps, youtube, battery used. how much?
  19. Sergeguliyev
  20. khattaksaab
