10
Unified OP3/3T Battery Thread
  1. Priyank Dhingra 123
    Froyo May 5, 2017
    skyla20 likes this.
  2. raevenzero
    Cupcake May 5, 2017
    raevenzero , May 5, 2017 :
    I thought it was all in my head, but last night I went to bed at 11pm with the battery at 50%. When I woke up at 6:30am, the battery was at 5%. I restarted it right before I went to sleep. Mobile data, location, and bluetooth were off. Phone was connected to 5Ghz Wifi.
    I was worried that I had something wrong since the phone is only a couple of weeks old. This thread seems to show that I'm not the only one. Android OS is the primary battery user.
    Any plans for integrated profiles that might help with this? I know there are profile apps out there, but I haven't rooted my phone so they can't interract with many of the high battery usage settings. It's annoying to have to go through a ton of settings every time my situation changes, but if I don't, I come back to a battery that has significantly less charge available. This happens even on standbye.
    I also notice that the dash charger usually only brings the battery up to 97-99%. Rarely do I see 100%. Is this common?
    jackjt8 likes this.
  3. youbi
    Assistant Head Moderator Assistant Head Moderator May 6, 2017
  4. Ludi Kure
    Eclair May 6, 2017
  5. MaximAmadi
    Eclair May 6, 2017
    MaximAmadi , May 6, 2017 :
    Would flashing to open beta 5, or even 6, improve battery performance if it's still poor with this 4.1.3 update? (after 2 weeks)
  6. G_Tony_Miram_Perme_NFdS
    Eclair May 6, 2017
    G_Tony_Miram_Perme_NFdS , May 6, 2017 :
    Please send an update. The new update is draining my battery life and it doesn't even last for a day with normal use. The app optimization is not good right now.
  7. diwakar_18
    Gingerbread May 6, 2017
    diwakar_18 , May 6, 2017 :
    try cache reset and check....if it doesn't work fine then perform a factory reset....if it doesn't fix.....try flashing using pc.....dont use beta's and turn off haptic.....i get 7 hrs Screen on time on average...(OTA might caused this issue).... good luck!
  8. G_Uchenna_Onodu_YtbP
    Cupcake May 6, 2017
  9. codgician
    Froyo May 6, 2017
  10. O7_Harish_Chandra
    Froyo May 6, 2017
    O7_Harish_Chandra , May 6, 2017 :
    Open Beta 6 Oneplus 3T , Most battery hungry update. Facebook/Youtube etc.Apps are consuming lot of battery about 20%.
    codgician likes this.
  11. O7_Harish_Chandra
    Froyo May 6, 2017
  12. gubro
    KitKat May 6, 2017
    SachinTS likes this.
  13. G_Manmohan_Chandak_AJcj
    Cupcake May 6, 2017
  14. FelipeMontecinos
    Cupcake May 6, 2017
  15. G_vishal_Kotadiya_bLSm
    Cupcake May 6, 2017
  16. JuanBarakat
    JuanBarakat , May 6, 2017 :
    After 4 months using oneplus 3t i never say to any one please give me your charger.
    I didn't need to charge my phone out my house.
    write your experience with battery......
    peaky blinders likes this.
  17. JasonMR
    Lollipop May 6, 2017
  18. Spinosaurus
    Ice Cream Sandwich May 6, 2017
    JasonMR likes this.
  19. G_T._A._CxNO
    zorkor likes this.
  20. shahvikram123
    Froyo May 6, 2017
    shahvikram123 , May 6, 2017 :
    My brother has the 3t for around a week now and he's also been saying the battery life is really good. Even though he plays games etc
    JuanBarakat and athaarv like this.
