6
Unified OP3/3T Battery Thread
  1. Topper_Gas
    Jelly Bean Oct 29, 2016
    Topper_Gas , Oct 29, 2016 :
    But if 100% is really 97% surely 97% is only then 94% on that basis? I've noticed my phone drops quickly for the first 10% then slowly discharges, like the brightness and volume controls I guess the readings aren't calibrated correctly?
  2. Disgruntledemployee
    Cupcake Oct 30, 2016
    Disgruntledemployee , Oct 30, 2016 :
    This is very likely due to the stock kernel. Although it is weird that it drops 3% that easy. Definitely monitor the apps that may be leeching the battery. But if it shows you "Android OS" or "Screen", then that's as far as I can go with help :(
    Good luck and godspeed!
  3. bpwest80
    KitKat Oct 31, 2016
    bpwest80 , Oct 31, 2016 :
    On 3.2.7 my OP3 will drop about half a percent an hour. So if I unplug it before I go to bed and it just sits there for 8 hours, when I get up it's at around 96%. It varies a little but it's usually around 95%. So overnight it loses around 5% in 8 hours. I'm averaging around 6 hours SOT so far. That's pretty good. I have no complaints about the battery life on the OP3. Especially since I was used to using a Nexus 6p.
  4. Altaf1211
    Donut Dec 25, 2016
    Altaf1211 , Dec 25, 2016 :
    after updating OS software battery drain fast... even mobile is in standby it will automatic discharge...
    please resolve ASAP
  5. Kutbi1678
    Donut Dec 25, 2016
    Kutbi1678 , Dec 25, 2016 :
    Even I am feeling the same issues. Battery is draining very fast. Enclosed my IMEI details.
  6. anuj bhatia
    Cupcake Dec 25, 2016
    anuj bhatia , Dec 25, 2016 :
    battery is draining very fast I bought my 3t recently but even device is closed battery start draining even not lasting full day. kindly resolve this issue
  7. Harsimransingh26
    Gingerbread Dec 25, 2016
    Harsimransingh26 , Dec 25, 2016 :
    Same here
    When i bought oneplus 3t with built in version it gave an awesome battery life but after 3.5.4 it sucks.
    Please try to improve these issues.
  8. sumit.anand
    Donut Dec 25, 2016
  9. Baibhav_Kumar
    Honeycomb Dec 25, 2016
  10. G_Amrinder918
    Donut Dec 25, 2016
  11. rammohangs
    Eclair Dec 25, 2016
    rammohangs , Dec 25, 2016 :
    even I face the same problem of battery drain.if you notice even the finger print sensor is bit slow to react after the update .
  12. G_Something_Serious_T.V.
    Donut Dec 25, 2016
  13. Funk Wizard
    Lollipop Moderator Dec 25, 2016
    Funk Wizard , Dec 25, 2016 :
    No such problems.. I repeatedly get over 6 to 8 hours of SOT
    Edit: Did you try clearing cache after the update?
  14. G_SURYAKANTA_SAHU_SdaD
    Donut Dec 25, 2016
  15. Asaajid
    Asaajid , Dec 25, 2016 :
    Battery starts reducing while on charge, battery reduces real fast, 2-3 hrs battery backup after d update... Pls get this fixed ASAP
  16. Asaajid
    Network fluctuation is high and can't use the phone for more than 5mins after the upgrade
  17. Harsimransingh26
    Bro
    [iFunk Wizard, post: 15510294, member: 218434"]No such problems.. I repeatedly get over 6 to 8 hours of SOT
    Edit: Did you try clearing cache after the update?[/QUOTE]
    , is this
  18. Harsimransingh26
    @iFunk wizard a lot of people are saying thing same as me, i guess you should throw a lil light over it...
    #38
  19. rahulmm
    rahulmm , Dec 25, 2016 :
    If I leave my Bluetooth on always, I'm losing a lot of battery, even on standby. I am used to leaving Bluetooth ON always, so this is a bug. Having to turn it on and off as I need it is disgraceful.
    #39
  20. udit jaiswal
    udit jaiswal , Dec 25, 2016 :
    for me also the same problem battery sucks...it is only giving 3-4 hrs backup,even in standby mode battery discharge automatically.
    #40
