10
Unified OP3/3T Battery Thread
  1. Dr.sachin
    Donut Mar 8, 2017
    Dr.sachin , Mar 8, 2017 :
    when they will solve the play store issue for roaming network in 7.0/4.0.3
  2. Pweibj67
    Froyo Mar 8, 2017
    Pweibj67 , Mar 8, 2017 :
    Why the hell has no body thought of this? You could be on to something. Think they should increase it least a week plus use solar charging and kinetic transfer...!
  3. BobbyV8_
    The Lab² Reviewer - Insta360 GO 2 Mar 8, 2017
    BobbyV8_ , Mar 8, 2017 :
    Answered :p
  4. BobbyV8_
    1. Wrong thread
    2. It is an issue from Google end. people are on the move to fix it
    F_SacHin_George_Sjkz likes this.
  5. Nimrodiny
    Gingerbread Mar 8, 2017
    Nimrodiny , Mar 8, 2017 :
    For the first time ever, I'm experiencing HORRENDOUS BATTERY LIFE on my OP3, running OOS 4.0.3.
    Something is clearly wrong here. On previous Nougat based versions I used to get around the 4.5 SOT with one day total and 4-5% drain over night. It slowly went down to 3 SOT on half a day. And now?25% overnight with 30 min of SOT and I'm already at 61%. Absolutely ridiculous.
    I've tried everything. Trust me. Clearing cache, factory reset, battery calibration, clean flash again, turning off backup, EVERYTHING. I'm using the same accounts, patterns and apps as I've always been. I know my mobile reception is so-so. It's always been that way and I got 8 hours SOT on Marshmallow.
    This is absurd and needs to be fixed ASAP. I know for sure that I'm not the only one complaining, just look around.
    And yes, I searched the forums, no real solutions out there. I don't usually open threads like this, but Oneplus has to acknowledge this issue. It's a deal breaker for me.
    misterscc likes this.
  6. Android450
    Marshmallow Mar 8, 2017
    Android450 , Mar 8, 2017 :
    If you're feeling up to it, I recommend going to the beta until a stable build is released. 4.0.3 has too many issues
    Nimrodiny likes this.
  7. Scherpenseel
    KitKat Mar 8, 2017
    Scherpenseel , Mar 8, 2017 :
    4.0.3. has some serious battery issues when using GPS. But indeed try the Beta, it's solid as a rock!
  8. darius1988
    KitKat Mar 8, 2017
    darius1988 , Mar 8, 2017 :
    Me to , the last few days over night I lost 10% and normaly is 3%, and sistem eat a lot. In my case I think is wifi problem , because last night I turn off wifi and I lose only 2%. I am gone investigate more. Something is wrong , because I usely got more then 5,5 hours sot over 1,5 days , and now 4 hours over 1 day ... I am tired clear always cache and Factory reset , the phone works good 1 week then got slowly, lagging and batterry drain faster , and I use only few apps , always the same apps: YouTube, Chrome, comunity, wassap, viki movie, Badoo,asfalt 8 and Tiger ball. I Hope that the new update resolve all problems.
  9. yash17
    Eclair Mar 8, 2017
    yash17 , Mar 8, 2017 :
    Facing similar issue..battery life was fine a couple of days back but now suddenly things have become unbearable. Battery drains very fast and Android System and OS appear to be the main culprits. Can anyone suggest what I should do? Factory Reset did not help :/
  10. darius1988
    KitKat Mar 8, 2017
    Me to , from last few days 10% over night, the last night I tried with wifi off and the phone lose only 2%, I think is a wifi problem.
  11. Nimrodiny
    Thanks for your comments guys. I might give the beta a try although I'm usually using ONLY stable builds. Unfortunately as you can tell 4.0.3 is far from being stable.
    Is beta 12 really stable?
    Android450 likes this.
  12. ghostofcain
    ghostofcain , Mar 8, 2017 :
    The title says it all in capitals to avoid any confusion "ANOTHER" battery life thread complaining of exactly the same problems with exactly the same solutions. This would be better resolved by reading the release thread or one of the other battery threads.
  13. Android450
    Yup working like a charm for me do a clean flash and you should be golden
  14. rarog
    Assistant Head Moderator Assistant Head Moderator Mar 8, 2017
    rarog , Mar 8, 2017 :
    I merged multiple OP3 battery threads into one, please stick to this thread and don't open new pointless threads.
    As if this plea will stop anybody... *sad face*
  15. Jasonlhleung
  16. G_Patryk_B_sbbc
    Nimrodiny and qvert like this.
  17. darius1988
    KitKat Mar 8, 2017
    No, with data on are consumed more then with wifi, general with data batterry are drain fast, but I don't use data I use wifi .
  18. Prateek_Nayal
    Cupcake Mar 8, 2017
    Prateek_Nayal , Mar 8, 2017 :
    Hi please find below screenshot
    Let me know if anything else required
  19. YASHGALIYA
    Eclair Mar 8, 2017
  20. YASHGALIYA
    Eclair Mar 8, 2017
