2
Unified OP3/3T Battery Thread
  1. CasRaven
    Eclair Jan 23, 2018
    CasRaven , Jan 23, 2018 :
    I've tried everything in the thread. I've reset my phone twice. The second time I erased everything from my phone and reinstalled Oreo via the ADB Sideload method. Still my SoT isn't more than barely 3 hours.
  2. G_koushal_agarwal_GSyq
    Eclair Jan 24, 2018
  3. knonn
    Donut Jan 24, 2018
    knonn , Jan 24, 2018 :
    For all who experienced battery drain issue after oos 5.0.1 upgrade, I fixed this by doing a clean install using the full ROM flashing via TWRP. A simple reset of the phone didn't do anything for me.
    You need to wipe everything including internal storage and install latest oos 5.0.1. When the installation is completed, you need to reboot on TWRP before booting on the system and select "Keep Read Only" when TWRP ask you. If you don't do this, the recovery will be overwritten by the ROM.
    I hope this help some of you guys. Feel free to ask me if you have any question.
    ravidesai47 likes this.
  4. knonn
    Donut Jan 24, 2018
  5. shabab0477
    Donut Jan 24, 2018
    shabab0477 , Jan 24, 2018 :
    unable to open PDF files . While dailling it's showing error report or close application
  6. ravidesai47
    Honeycomb Jan 24, 2018
    ravidesai47 , Jan 24, 2018 :
    I am also facing the same issue after Oreo upgrade.
    Before Oreo battery was working very well.
    But after Oreo battery performance degraded noticably.
    OnePlus should fix the battery performance issue.
  7. knonn
    Donut Jan 24, 2018
    Please read #6307
  8. ravidesai47
    I will try it out...
  9. chetanx
    Donut Jan 25, 2018
    chetanx , Jan 25, 2018 :
    I'm facing battery draining issue from yesterday, the situation is so worst that I have to change my phone atleast 7-8 time. And recently the clear cache from recovery.
  10. Rahul Dayal
    Gingerbread Jan 25, 2018
    Rahul Dayal , Jan 25, 2018 :
    I too have battery issue
    but they are not responding
    74% battery consumed by Android system
  11. G_Alxs_pineda_vnmm
  12. pablofg1978
    Spanish POC Assistant Head Moderator Jan 25, 2018
    pablofg1978 , Jan 25, 2018 :
    Merged
    chetanx likes this.
  13. Hydra Bob
    Marshmallow Jan 25, 2018
    Hydra Bob , Jan 25, 2018 :
    Wait 1 day 1 hr since last full charge and 7.5 hrs screen time? Are you sure that you didn't charge in between? Because if so those battery stats are impossible to judge. Give us the full battery graph, then we'll have something to go by.
  14. Rahul Dayal
    Hydra Bob
    Wait 1 day 1 hr since last full charge and 7.5 hrs screen time? Are you sure that you didn't charge in between? Because if so those battery stats are impossible to judge. Give us the full battery graph, then we'll have something to go by.​
    I have charged in between obviously
    I don't charge to 100% every time
    I charge upto 70-80%
    which was used to be enough for the whole day for me before the update
    idk something went wrong after the update
    I don't use Facebook Instagram Snapchat or messengers and all (apps known for sucking battery)
    and I've cleared my cache as well
    don't worry
    I'll show u today's battery stats by the end of the day
  15. shivendravats
    Cupcake Jan 25, 2018
    shivendravats , Jan 25, 2018 :
    My OnePlus3T battery drains quickly, a full charge doesn't last for 2 hours. This has happened after the Oreo update and another patch that came a few days back
    Rahul Dayal likes this.
  16. Davidpieters1978
    Davidpieters1978 , Jan 25, 2018 :
    There are other threads dedicated to this.
    But mostly delete cache and data solve a lot.
    There is a workaround explained in the 3t forum.
  17. shivendravats
    Thanks David, will try deleting cache.
  18. Davidpieters1978
  19. GopalB.
    Nougat Jan 25, 2018
  20. pablofg1978
    Merged
