Unified OP3/3T Battery Thread
  1. pablofg1978
    Spanish POC Assistant Head Moderator May 28, 2018
    pablofg1978 , May 28, 2018 :
    Same, I don't notice any difference.
    Check your battery stats and post it here
  2. Sivarkvarma7
    Donut May 28, 2018
    Sivarkvarma7 , May 28, 2018 :
    just now i charged the device ,i will post definitely
  3. tushar.gaikwad
    Gingerbread May 28, 2018
    tushar.gaikwad , May 28, 2018 :
    The New 5.0.3 update is really good on OP3. Feels that the battery life is somewhat better than the previous 5.0.2 OS.
    Let it settle for a day after the update and then clear cache by going into recovery mode! [e]270c[/e]
  4. 29071994
    Donut May 29, 2018
  5. pablofg1978
    Spanish POC Assistant Head Moderator May 29, 2018
  6. iCoerce
    Froyo May 30, 2018
  7. Cas81
    Cupcake May 30, 2018
  8. S1511889617034
  9. pablofg1978
    Spanish POC Assistant Head Moderator May 30, 2018
    pablofg1978 , May 30, 2018 :
    Thread merged
  10. santhosh311983
    Honeycomb May 31, 2018
    santhosh311983 , May 31, 2018 :
    we have paid for the device to use it effectively ..not to run behind this battery issues .. frankly its not the user who has to troubleshoot this issue ..OnePlus just need to do analysis and then release an OTA update to curb this issue ...
  11. Athian1991
    Froyo May 31, 2018
    Athian1991 , May 31, 2018 :
    Worst battery life after updating 5.0.3. And also lots of bugs in this update. Parallel Space app keep crashing. Can't open any of single whatsapp msg in parallel space app.
  12. Deactivated User
    May 31, 2018
  13. ph6058
    Gingerbread May 31, 2018
    ph6058 , May 31, 2018 :
    that battery time isn't right . it is calculating and after an update it got reset and has to recalculate .
  14. aman.khade
    Cupcake May 31, 2018
    aman.khade , May 31, 2018 :
    very bad battery life after 5.0.3, also heating a lot for unnecessary stuff like browsing the net.
  15. ph6058
    for me battery life hasn't changed . I cleared cache after update in "bios" (forgot the name) and it's about 5 hours sot. it gets quite hot now but that I guess has to do with cache clearing and the update plus it's 28 degrees .
  16. ghostofcain
    Marshmallow May 31, 2018
    ghostofcain , May 31, 2018 :
    An OTA from OnePlus will not sort out rogue 3rd party apps, if you think it will then you are frankly deluded.
    prashanth.jagannath likes this.
  17. RawRs
    RawRs , May 31, 2018 :
    For me, my SOT improved a lot .. From barely 3 hours to now more than 3.5 hours on average ...
    Parallel Apps works fine too ...
    Maybe you can try to reinstall / reflash the update manually ...
    It would help fix bugs
  18. santhosh311983
    can you please define your 3rd party apps clams ? ..cos most of the users install app from play store and some install 3rd party APK ..least OnePlus releases an seperate OTA only for battery so it can narrow down the stats of users who are facing battery issue
  19. PTuT
    Jelly Bean May 31, 2018
    PTuT , May 31, 2018 :
    Same here, my battery life is much better than it was on 5.0.1. Also the WiFi bug when button after deep sleep stopped working and one could not enable WiFi is gone. Happy camper here.
    RawRs likes this.
  20. ghostofcain
    Can you name one OEM who would narrow down the battery stats of users with problem battery life, when the majority of users don't have issues? As for 3rd party apps I am referring to any apps made by a 3rd party ie that aren't made by OnePlus.
    A little work by you, reading the pinned battery threads would reap dividends, but no, that's too much to expect.
