Unified OP3/3T Battery Thread
  1. 29071994
    Donut Jul 11, 2018
    29071994 , Jul 11, 2018 :
    this is my 5 or 7 post .
    max screen on time i a getting 2-3 hrs .
    if any one who faced same problem but resolved it now.
    kindly give me some ideas to maintain atleast 6hrs .
    thanks in advance.
  2. pablofg1978
    Spanish POC Assistant Head Moderator Jul 11, 2018
    pablofg1978 , Jul 11, 2018 :
    Thread merged
  3. santhosh311983
    Honeycomb Jul 12, 2018
    santhosh311983 , Jul 12, 2018 :
    Getting great SOT and standby time after removing / disabling some apps from "Device Administrators" ..specially outlook app which I did not had the control of sync ..
    OOS version 5.0.3 ..
  4. santhosh311983
    check what apps are enabled in "Device Administrators" ..if possible deactivate them and then check the SOT ..
  5. 29071994
    Donut Jul 13, 2018
    29071994 , Jul 13, 2018 :
    their is no app except device find
  6. matija14
    Cupcake Jul 13, 2018
    matija14 , Jul 13, 2018 :
    It is now a bit too much. I can barely get it through a day...2h of SOT is max.
  7. santhosh311983
    Honeycomb Jul 13, 2018
    santhosh311983 , Jul 13, 2018 :
    Seems to be that your signal reception is too much fluctuating ...check with your network service provider or change the sim and give an Try !!
  8. Rachitagra15
    Cupcake Jul 15, 2018
  9. Sun90
    Starting Point Expert Jul 15, 2018
    Sun90 , Jul 15, 2018 :
    Do check the pinned battery threads fir some useful tips.
  10. brolin_
    Cupcake Jul 16, 2018
    brolin_ , Jul 16, 2018 :
    I recommend the app: GREENIFY
    It will hibernate your apps that drains the battery.
    I just got 5h SOT instead of my average 3-3,5h. (100% to 5%)
    Using Facebook, Instagram, Chrome, Snapchat, Runkeeper as i usually do.
  11. brolin_
  12. Jaimeen Trivedi
    Jaimeen Trivedi , Jul 16, 2018 :
    hi,
    I have been using One plus 3T from past 2 years. From last one month I am observing that my phone battery drains very quickly which was never the case before. It gets drain even in flight mode.
    No other complaint with the device. if it calls for replacing the same, pls guide where I can get in changed & the cost?
  13. pablofg1978
    Spanish POC Assistant Head Moderator Jul 16, 2018
    pablofg1978 , Jul 16, 2018 :
    Thread merged
  14. RASTAVIPER
    Jelly Bean Jul 17, 2018
  15. O1517748186008
    Cupcake Jul 17, 2018
  16. G1529805024277
  17. G_Sankalp_K.C_CWal
    Cupcake Jul 18, 2018
    nabsrai likes this.
  18. G_Sankalp_K.C_CWal
  19. Mkmanis11
    Gingerbread Jul 18, 2018
  20. Petjitsu
    KitKat Jul 18, 2018
    Petjitsu , Jul 18, 2018 :
    Screenshot_20180718-212147.jpg :D:D;)
    tisko4 and Bobbie63 like this.
