346
Unified OP3/3T Battery Thread
  1. johnhart Ice Cream Sandwich Aug 21, 2018
    johnhart, Aug 21, 2018 :
    So I believe my phone's issue was only heat. The OP3 got warm because it was hot out... and it China Syndromes. That is: the heat causes it heat up even more... which causes it to heat even more... which kills the battery until cooled.
  2. Josefine_Paaske Cupcake Aug 21, 2018
    Josefine_Paaske, Aug 21, 2018 :
    I don't have the heat problems, can it be something related to the latest update?
  3. anutosho Cupcake Aug 21, 2018
    anutosho, Aug 21, 2018 :
    Is it a good idea to install something from an unknown source that doesn't even contain an info file telling me what this script will do with my phone? I wouldn't install that.
    Besides of that the link to the OOS-Debloater.zip is dead, anyway.
  4. DA7801 Honeycomb Aug 25, 2018
    DA7801, Aug 25, 2018 :
    Guys I've been searching threads regarding improving battery life, but some of them aren't updated or require a specific firmware.
    So my question is can please someone tell me how to imorove battery life on 3T? Currently getting 4-4.30hrs pf SOT with 9.30hrs of usage.. Also i cannot find the solution as to why android system is always on the top. Help needed.. Thank you!
  5. sprungy Cupcake Aug 25, 2018
    sprungy, Aug 25, 2018 :
    I've got an LG G5 through work. My OnePlus 3 spanks it every time in battery life. The LG just isn't great for battery. I'm currently on official Oxygen OS 5.0.4 running the dark theme.
    I'm still eyeballing the ZeroLemon 7,500 mAh battery case however cause I truly prefer going days without charging.
  6. Poonam Rajpoot Donut Aug 29, 2018
    Poonam Rajpoot, Aug 29, 2018 :
    Hi
    I am also facing a fast battery drainage issue since last 3-4 days. Initially in the night without any usage n internet connectivity even battery drained down from 80% to 14% and during day time also drainage is very fast even idle situation. I posted a separate thread on this issue n was asked to full charge the battery in the night n kept it without any usage n internet whole night to share the battery usage log in the morning. Since my that separate thread has been closed without any solution hence posting the battery log screen shots here. Yesterday though drainage wasn't that drastic but from 99% to 78% that too without any use n internet connectivity is also worrisome. Pls help.
    Thanks
  7. yashgupta018 Cupcake Aug 29, 2018
  8. neihnana Froyo Aug 31, 2018
    neihnana, Aug 31, 2018 :
    Some help me I purely use my 3t as my game phone airplane mode on power saver on, no big background draining apps like Instagram Facebook doze is off because I found I'd loose 45mins on sot, my issue is a full charge last only 6hrs, i use to get 12 to 13 hrs of a charge anyone know what rom I should run
  9. abiskar Froyo Sep 2, 2018
    abiskar, Sep 2, 2018 :
    my one plus 3 is giving Awesome Battery life.
    oos 5.0.5
    i am impressed
  10. abiskar Froyo Sep 3, 2018
    abiskar, Sep 3, 2018 :
    Battery life has significantly increased in my oneplus 3 after upgrading to oos 5.0.5
    Justin Yap likes this.
  11. Justin Yap Gingerbread Sep 3, 2018
    Justin Yap, Sep 3, 2018 :
    4 hour 27 minute at 27 % left is normal usage , you have used a lot of app , try refer your battery stats .....
  12. anz563 Ice Cream Sandwich Sep 3, 2018
    anz563, Sep 3, 2018 :
    Hi guys. I've recently used Magisk 16.1 and everything was fine. When new version 17.1 was come out, I wanted to update it immediately. I disabled all modules ( actually i used just one module: dns4crypt), clicked for delete them, rebooted to recovery, deleted Magisk by latest Magisk Uninstaller, rebooted recovery, then installed Magisk 17.1 and wiped cache and dalvik cache. After phone gets booted up, I let him lie down for a bit to make complete all background processes. After about 30 minutes of phone lying down I start to use my phone. All apps, that need root, get it. But I have one problem, that very very annoying  After a small using phone gets really hot! Processor is not loaded high, doesn't get full 100% load, everything in general works smooth and fast but when I lightly using phone at about 20-30 seconds, phone comes really hot.. Can you give me an advance? Why phone overheating after Magisk update without any loading? Please, I can't find a solution..
    OnePlus 3T, oxygen os 5.0.5, stock kernel
  13. Justin Yap Gingerbread Sep 3, 2018
    T1533782354700 likes this.
  14. dimovkster Honeycomb Sep 4, 2018
  15. dimovkster Honeycomb Sep 4, 2018
  16. Justin Yap Gingerbread Sep 4, 2018
    Justin Yap, Sep 4, 2018 :
    turn on battery saving mode when not use/idle , lower down screen brightness, I turned on night mode so that the screen is a bit dim (not sure that really helps increase battery life) , using Facebook lite
  17. Justin Yap Gingerbread Sep 4, 2018
  18. dimovkster Honeycomb Sep 4, 2018
    f00tbaLL and Justin Yap like this.
  19. Q1509636989918 Cupcake Sep 6, 2018
    Q1509636989918, Sep 6, 2018 :
    Turn off VOLTE
    f00tbaLL likes this.
  20. ERock62 Gingerbread Sep 11, 2018
