339
Unified OP3/3T Battery Thread
  1. G_Syedali_J_xWHT Cupcake Dec 21, 2018
    G_Syedali_J_xWHT, Dec 21, 2018 :
    My battery backup is so poor after the update of Oxygen OS 5.0.8, I tried to clear Cache from recovery but still the battery backup is not good I'm getting hardly 2 hrs of SOT.
    I've tried clean installation of Oxygen OS 5.0.8 but still no improvement in battery life..
    Also I reverted back to OOS 5.0.6 the issue remained the same. But before the update used to get 4.30 to 5 hrs of battery backup.
    Please give me a solution for this issue
    I've attached the screenshots of the battery consumption
  2. tpati Gingerbread Dec 23, 2018
    tpati, Dec 23, 2018 :
    Anyone have a battery drain on cell standby on 5.0.8? Have wipe and clean everything and this bug appears again..
    There is a way to solve it?
  3. G_Sanket_Trivedi_tyXa Cupcake Dec 25, 2018
  4. Shahid Hakkim Froyo Dec 27, 2018
    Shahid Hakkim, Dec 27, 2018 :
    Guys..
    just wanna know the price of Original 3T Battery nd Touch Screen(Not Full Display) in India..???
    My Battery is Now worse...
    Has only 2800 mah Health when checked in BBS
    Did anyone ever bought those two?
    C1521407593687 likes this.
  5. C1521407593687 Cupcake Dec 27, 2018
  6. G_Ankit_Kumar_pYkC Cupcake Dec 28, 2018
  7. _AppleJuice_ Cupcake Dec 31, 2018
    _AppleJuice_, Dec 31, 2018 :
    Same here, 1 day and half with all day use. After 5.0.8 i need to recharge half battery for arrive at 10 pm with 5%. I see more battery drain from stand-by operation.
  8. _AppleJuice_ Cupcake Dec 31, 2018
    This is ridiculous. One update can destroy a phone. My old nexus 5 with 6 years of use, have more battery life. I need to put this oneplus in the trash can. See photo, only 6 hours of battery life with all night charge with phone off. ****. Before this update i can make easy 30 hours of battery. 30 to 6. I don't have time for adjust this sheet to myself, they need official update, max 2 days.
  9. C1521407593687 Cupcake Dec 31, 2018
    _AppleJuice_ likes this.
  10. Shahid Hakkim Froyo Jan 1, 2019
    Shahid Hakkim, Jan 1, 2019 :
    Guys... I have a doubt
    My 3T's Battery backup nd screen on time is very bad..
    It's been 1.5 years only..
    I need to charge more than 2 times a day!
    When checked with BBS... Only 2800mah is available out of 3400mah....!
    I am in thinking to change the Battery..
    Shuld i do it?
    Please Respond[e]1f64f[/e]
  11. jnsson Honeycomb Jan 3, 2019
    jnsson, Jan 3, 2019 :
    Yes, if you need to charge it during the day, then I would have replaced the battery
    Shahid Hakkim likes this.
  12. Shahid Hakkim Froyo Jan 3, 2019
    Shahid Hakkim, Jan 3, 2019 :
    Thanks Bro[e]2764[/e]️
  13. Topper_Gas Jelly Bean Jan 3, 2019
    Topper_Gas, Jan 3, 2019 :
    Replacing the battery won't stop a rogue app etc draining the battery, put the phone in safe mode for a few hours and see if the drain continues, if it does it sounds like a battery issue, if it doesn't it's non standard app you've installed.
  14. tpati Gingerbread Jan 5, 2019
    tpati, Jan 5, 2019 :
    Have a huge battery drain on cell standby with 20-40% on battery.
    Wipe and clean cache didn't work, reinstalled 5.0.8 OTA with local update didn't work too.
    There's solution? This bug didn't appears on OOS 5.0.6
  15. MrHari_theCarguy Jelly Bean Jan 5, 2019
    MrHari_theCarguy, Jan 5, 2019 :
    I updated my OP3T to oxygen os 5.0.8 about 2 weeks ago,I had wiped cache from recovery after updating my phone.but for the past two days my battery is acting wierd.2 days ago I used my phone before going to bed and battery was 41%.when I woke up the next day, battery was at 22%.i put my phone on charge and it charged quickly as usual,then yesterday after some time of usage the phone was idle for some time and there was no battery drain and later when I used the phone it took like an hour for 1% drain in battery and once it does battery drained rapidly .this was happening every time I used my phone after phone was idle.pls help solve this frustrating and wierd issue as I don't think it's the problem with the actual battery but rather a software bug introduced after the latest update
  16. techonetwo Cupcake Jan 6, 2019
    techonetwo, Jan 6, 2019 :
    Hi guys, I have passed from Oxygen OS Beta (because there aren't new updates from July) to Oxygen OS Stable 5.0.8 on my OP3. But I noticed a great battery drain... it passes from 100% to 30% in few hours of usage.
    kashishkhanna55 likes this.
  17. Topper_Gas Jelly Bean Jan 7, 2019
    Topper_Gas, Jan 7, 2019 :
    What do you expect forum users to do or suggest? All you can do is trying and find out what is draining your battery, as a start have you checked your battery usage stats, if so, is one app draining the phone more than it should? Does it drain over night as well as during the day when the phone is not in use?
  18. decayed Donut Jan 8, 2019
  19. Q1545275038674 Cupcake Jan 11, 2019
    Q1545275038674, Jan 11, 2019 :
    Battery costs 1651/- including Labour. just got it changed the day before
  20. Shahid Hakkim Froyo Jan 18, 2019 at 2:01 AM
    Shahid Hakkim, Jan 18, 2019 at 2:01 AM :
    How's the Battery life??
    Any Major difference?
