370
Unified OP3/3T Battery Thread
  1. pablofg1978
    Spanish POC Assistant Head Moderator Aug 6, 2018
    pablofg1978 , Aug 6, 2018 :
    Thread merged
  2. G_himanshu_garg_APsO
    Donut Aug 6, 2018
    G_himanshu_garg_APsO , Aug 6, 2018 :
    Hi
    I'm getting this same issue.
  3. Abir_hossain
    Eclair Aug 6, 2018
    Abir_hossain , Aug 6, 2018 :
    Please do something for op3 cause battery draining is too much fast [e]1f614[/e][e]1f614[/e]
    After update
  4. Sun90
    Starting Point Expert Aug 6, 2018
    Sun90 , Aug 6, 2018 :
    No one can do anything in here, unless you post relavent screenshots of the same.
    Abir_hossain likes this.
  5. pablofg1978
    Thread merged
    Please use the search before creating a new thread
  6. Dresa91
    Android Q Aug 7, 2018
    Dresa91 , Aug 7, 2018 :
    think it depends on the last two Google Calendar updates...
    @Sun90: do you use Google Calendar too?
    Sun90 likes this.
  7. Sun90
    Starting Point Expert Aug 7, 2018
    Sun90 , Aug 7, 2018 :
    Yes.
    And haven't had any issue so far with it.
  8. Dresa91
    strange.. because I got the same notification... My version is 5.8.42, and yours?
  9. Sun90
    Same version.
    I always keep the Google apps up-to-date.
    Only Google app and Google play services are on their beta builds.
  10. Dresa91
    ok.I am using just the services, play store and calendar. all other google apps are disabled.
    @Bobbie63: what's about you? Do you use Google Calendar?
    Bobbie63 likes this.
  11. Bobbie63
    Marshmallow Aug 7, 2018
    Bobbie63 , Aug 7, 2018 :
    Yes, I do. Can't say I have any issues and I have the same version.
    Dresa91 likes this.
  12. Dresa91
    ok, thanks you:)
    I updated my GPS to the current version, so let's see:) (and cleared cache of calendar and GPS of course :) )
  13. Deactivated User
    Aug 7, 2018
  14. Bruxner
    Gingerbread Aug 7, 2018
    Bruxner , Aug 7, 2018 :
    I have had a OnePlus 3T for 7 months now and I have seen threads about the battery life being bad. I am quite careful with my battery and am actually a little obsessed with making it last as long as possible.
    If I keep battery save on, and have wifi, data, Bluetooth, location and NFC off most of the time I can get over 8 hrs of screen on time. Typically, though, I get between 6 and 7 hours. This is so much better than my last phone (Samsung galaxy s5) and I am so happy with this phone.
  15. pablofg1978
    Spanish POC Assistant Head Moderator Aug 7, 2018
    pablofg1978 , Aug 7, 2018 :
    Thread merged
    Please use the existing battery thread
  16. sdkr1980
    Donut Aug 8, 2018
    sdkr1980 , Aug 8, 2018 :
    hi all,
    Got a better SOT on my oneplus 3., with a simple trick..
    Drain your phone battery completely until it gets shutdown by itself.. charge the battery till 100% in switch off mode.. try to do it at least twice.. Also, do it after each update..
  17. KiranKumar.yadav
    Cupcake Aug 8, 2018
    KiranKumar.yadav , Aug 8, 2018 :
    one day lo automatically solove the probleam same prbleam in my mobile in one pluse 3t you will wait for oneday
  18. Amarjeet Sahoo
    Gingerbread Aug 9, 2018
  19. Dresa91
    Android Q Aug 9, 2018
    Dresa91 , Aug 9, 2018 :
    well for me it looks ok:)
    You are using mobile network and a lot of Apps, like insta.
  20. Amarjeet Sahoo
    Amarjeet Sahoo , Aug 9, 2018 :
    Maybe I am being hyper with the SOT but it used to be better previously. SOT on full charge is around 3 to 3:30 hrs as of now.
    Moreover Android system, Screen, Android OS, Google play services seems to be topping the list every time. If something of the 4 could come down, the SOT could be better..:(
