370
Unified OP3/3T Battery Thread
  1. Noni0ne
    Froyo Aug 12, 2018
  2. Titus Alajangi
    Cupcake Aug 12, 2018
  3. Bruxner
    Gingerbread Aug 12, 2018
    Bruxner , Aug 12, 2018 :
    I do recommend a replacement. It is advised to replace a battery when it gets below 80% maximum capacity, as yours is.
  4. J1527946883796
    J1527946883796 , Aug 12, 2018 :
    my 3T is working pretty Flawless as fast as hell I do lots of things I'm a download a holic my battery has expected drainage I can usually download movies and videos about six hours before I have to plug it in that's when the 15% warning comes on and then while downloading it's fully charged with in about 25 minutes I think you guys seriously need to think about some of the apps you're using
  5. aarushrajani
    Froyo Aug 12, 2018
    aarushrajani , Aug 12, 2018 :
    battery drain post 5.0.4 update.
    cleared cache, reinstalled full package of the software, but the experience is still of having a pretty extensive battery drain.
    i can literally see the battery percentage drop down as a timer clock countdown while I'm on my phone.
    I hope OnePlus can provide a quick fix.
    Noni0ne likes this.
  6. Noni0ne
    Froyo Aug 12, 2018
    Noni0ne , Aug 12, 2018 :
    is this normal???? i dont think it is!
    open beta had less battery problems! i hate this! do i need to buy a new phone? its not even one year
  7. aarushrajani
    Froyo Aug 12, 2018
    I had the same observation, andorid system on top, Instagram Facebook app activity showing hours and hours of being active in the background.
    did a clean factory reset , wiped cache , reinstalled the os but it's still the same.
    for one moment I even thought that it's time up for this phone, I bought it in December 2016.
    but I then figured that it was perfectly fine before the update, I hope OnePlus will consider the complaints of so many users and provide us with an effective solution with an update soon
    Noni0ne likes this.
  8. Bruxner
    Download an app called AccuBattery, charge ur phone and go to the battery health tab of the app. please take a screenshot and send it here.
  9. Noni0ne
    Froyo Aug 12, 2018
    i will, im going to drain it a bit more and the charge.
  10. Bruxner
    Noni0ne
    i will, im going to drain it a bit more and the charge.​
    Ok. Just so I can get an idea of ur battery life, what percent are you at now? (You were at 83% 20 mins ago)
  11. Noni0ne
    Froyo Aug 12, 2018
    78%, and i installed the app and thats it... replying here on the app.
    and thanks for replying and your time.
  12. UmarSyed456
  13. izzykasha
    Lollipop Aug 12, 2018
    izzykasha , Aug 12, 2018 :
    162 messages in the forum so can you tell me first what remediation actions you have taken (what have you done so far to try and solve this?)
    UmarSyed456 likes this.
  14. UmarSyed456
    UmarSyed456 , Aug 12, 2018 :
    i have cleared my cache and uninstalled and re installed whatsapp twice a day.
    izzykasha likes this.
  15. Basavaraj s nidgundi
  16. hahaha2223
    Jelly Bean Aug 12, 2018
  17. izzykasha
    cool right good, you know what comes next? one of these three options
    1) backup and full.factory reset deleting everything
    2) backup and flash a previous rom (earlier OOS version everything ran ok on)
    3) get onto the bug hunters and fill in a bug report and get them all your logs
  18. UmarSyed456
    everything in the sense?
  19. KMKris_05
    Donut Aug 12, 2018
    KMKris_05 , Aug 12, 2018 :
    install battery calibration app from play store and do as says...it will correct the bridge between physical battery power and software battery power
  20. PTuT
    PTuT , Aug 12, 2018 :
    Boot your phone to safe mode and observe if you have high battery drain. If not, then it's some rogue application you installed.
    Nick 59 likes this.
