6
Unified OP3/3T Battery Thread
  1. tarun2798
    Froyo Dec 8, 2018
    tarun2798 , Dec 8, 2018 :
    Google is draining my battery bro
    LakshayDhiman likes this.
  2. ghostofcain
    Marshmallow Dec 8, 2018
    ghostofcain , Dec 8, 2018 :
    Try uninstalling updates to the Google app, many users have reported success that way.
    tarun2798 likes this.
  3. RogerOriginals
    Ice Cream Sandwich Dec 8, 2018
    RogerOriginals , Dec 8, 2018 :
    Go to Settings>Apps>Application List and select Google from there. Then click Force Stop, then click Disable. Many users have reported that Google is draining a ton of battery, and this should help get your battery to normal in a day or two.
  4. LakshayDhiman
    Honeycomb Dec 8, 2018
    LakshayDhiman , Dec 8, 2018 :
    i would recommend u reset as best option then ...
  5. tarun2798
    Froyo Dec 8, 2018
    thnq...bro..I did.. factory data reset..now..it's fine
  6. tarun2798
    Froyo Dec 8, 2018
    I did bro..I shld see it now
  7. LakshayDhiman
    grt do share if it works so that others can get some info
  8. tarun2798
    Froyo Dec 8, 2018
    I just...did.. factory data..reset..and .I'm gonna say tomorrow..how..it works
  9. soubhikmullick14
    Cupcake Dec 8, 2018
    soubhikmullick14 , Dec 8, 2018 :
    If you guys are getting the notification of Google app using crazy battery and heating the phone, the fix is as follow:
    1. Uninstall Google App updates from google play store.
    2. Reinstall Google app updates.
    This will fix it.. i too had this issue and now my phone is back to normal.
  10. tarun2798
    Froyo Dec 9, 2018
    tarun2798 , Dec 9, 2018 :
    even my phone is back..bro...
  11. tarun2798
    Froyo Dec 9, 2018
    now...the phone is gud..no lagging and.. battery draining is not happening
  12. LakshayDhiman
    Honeycomb Dec 9, 2018
    LakshayDhiman , Dec 9, 2018 :
    cheers!!
  13. tarun2798
    Froyo Dec 9, 2018
    [e]1f4aa[/e][e]270c[/e]️[e]270c[/e]️
  14. G_Govinda_Pathak_OPhI
    Cupcake Dec 12, 2018
    G_Govinda_Pathak_OPhI , Dec 12, 2018 :
    look at that. getting 2 hrs of battery life. and surprisely it happed all of the sudden. i didn't update or do anything to a device. HELP GUYZ
  15. RogerOriginals
    Ice Cream Sandwich Dec 14, 2018
    RogerOriginals , Dec 14, 2018 :
    I upgraded to 5.0.7 a week back and I can now see the battery life has gotten excellent, just like new! Can't believe this phone will be 2 years old soon...
  16. Nandeesh221
    Cupcake Dec 17, 2018
    Nandeesh221 , Dec 17, 2018 :
    am also same problem till last update
  17. Nandeesh221
  18. G_Syedali_J_xWHT
    Cupcake Dec 18, 2018
    G_Syedali_J_xWHT , Dec 18, 2018 :
    I'm too having the same issue
    I'm on Oxygen OS 5.0.6 and not updated the system till now.
    But to my surprise I'm not getting more than 2 to 2.15 hrs of SOT for last 4 days
    Pls Help me to overcome this issue
  19. aloksingh_09
    aloksingh_09 , Dec 18, 2018 :
    This issue is really disappointing and should be dealt with asap as I have my rrb result coming soon. It is really important to be this glitch free.
  20. G_krishna_rakh_qeYT
    G_krishna_rakh_qeYT , Dec 18, 2018 :
    same here my oneplus 3 battery drain so quickly I noticed one thing I get notified Google is draining my battery but why it's happening I am so curious I hope oneplus will solve it oneplus please please please solve it and and take your time make a fine polish buy update for oneplus 3 and 3T please
