6
Unified OP3/3T Battery Thread
  1. pofak
    Cupcake Dec 19, 2018
    pofak , Dec 19, 2018 :
    What is happening with oneplus support, It's been more than 3 days and I still haven't received response to my ticket.
    UmarSyed456 likes this.
  2. railwayresult.in
    railwayresult.in , Dec 19, 2018 :
    Hello User, Once i faced this problem too. You should need to visit service centre rrb of One Plus and get checked your device or reboot your
  3. B1508471107175
  4. B1508471107175
  5. Pablo_Estevez
    Cupcake Dec 21, 2018
    Pablo_Estevez , Dec 21, 2018 :
    Hi, in my case uninstalling Google Fit fixed most of my problems. With Gsam I checked that there were several wakelocks from this app (this is important because in Batt % used you'll see Google Play Services or Android OS but in my case the culprit was Fit).
    Also switching location to battery saving mode helped a lot. Hope it helps.
  6. G_Syedali_J_xWHT
    G_Syedali_J_xWHT , Dec 21, 2018 :
    My battery backup is so poor after the update of Oxygen OS 5.0.8, I tried to clear Cache from recovery but still the battery backup is not good I'm getting hardly 2 hrs of SOT.
    I've tried clean installation of Oxygen OS 5.0.8 but still no improvement in battery life..
    Also I reverted back to OOS 5.0.6 the issue remained the same. But before the update used to get 4.30 to 5 hrs of battery backup.
    Please give me a solution for this issue
    I've attached the screenshots of the battery consumption
  7. tpati
    Gingerbread Dec 23, 2018
    tpati , Dec 23, 2018 :
    Anyone have a battery drain on cell standby on 5.0.8? Have wipe and clean everything and this bug appears again..
    There is a way to solve it?
  8. Sanket_Trivedi
    Cupcake Dec 25, 2018
  9. Shahid Hakkim
    Gingerbread Dec 27, 2018
    Shahid Hakkim , Dec 27, 2018 :
    Guys..
    just wanna know the price of Original 3T Battery nd Touch Screen(Not Full Display) in India..???
    My Battery is Now worse...
    Has only 2800 mah Health when checked in BBS
    Did anyone ever bought those two?
    C1521407593687 likes this.
  10. C1521407593687
    Cupcake Dec 27, 2018
  11. G_Ankit_Kumar_pYkC
    Cupcake Dec 28, 2018
  12. _AppleJuice_
    Cupcake Dec 31, 2018
    _AppleJuice_ , Dec 31, 2018 :
    Same here, 1 day and half with all day use. After 5.0.8 i need to recharge half battery for arrive at 10 pm with 5%. I see more battery drain from stand-by operation.
  13. _AppleJuice_
    This is ridiculous. One update can destroy a phone. My old nexus 5 with 6 years of use, have more battery life. I need to put this oneplus in the trash can. See photo, only 6 hours of battery life with all night charge with phone off. ****. Before this update i can make easy 30 hours of battery. 30 to 6. I don't have time for adjust this sheet to myself, they need official update, max 2 days.
  14. C1521407593687
    _AppleJuice_ likes this.
  15. Shahid Hakkim
    Gingerbread Jan 1, 2019
    Shahid Hakkim , Jan 1, 2019 :
    Guys... I have a doubt
    My 3T's Battery backup nd screen on time is very bad..
    It's been 1.5 years only..
    I need to charge more than 2 times a day!
    When checked with BBS... Only 2800mah is available out of 3400mah....!
    I am in thinking to change the Battery..
    Shuld i do it?
    Please Respond[e]1f64f[/e]
  16. jnsson
    Gingerbread Jan 3, 2019
    jnsson , Jan 3, 2019 :
    Yes, if you need to charge it during the day, then I would have replaced the battery
    Shahid Hakkim likes this.
  17. Shahid Hakkim
    Shahid Hakkim , Jan 3, 2019 :
    Thanks Bro[e]2764[/e]️
  18. Topper_Gas
    Jelly Bean Jan 3, 2019
    Topper_Gas , Jan 3, 2019 :
    Replacing the battery won't stop a rogue app etc draining the battery, put the phone in safe mode for a few hours and see if the drain continues, if it does it sounds like a battery issue, if it doesn't it's non standard app you've installed.
  19. simirad_bogdan
    Eclair Jan 3, 2019
    simirad_bogdan , Jan 3, 2019 :
    My phone needs to be charged twice a day or three times.
    I am using the lastest update. I don't this is ok.
  20. Mindanao
    Cupcake Jan 5, 2019
    simirad_bogdan likes this.
