6
Unified OP3/3T Battery Thread
  1. Mindanao
    Cupcake Jan 5, 2019
    simirad_bogdan likes this.
  2. tpati
    Gingerbread Jan 5, 2019
    tpati , Jan 5, 2019 :
    Have a huge battery drain on cell standby with 20-40% on battery.
    Wipe and clean cache didn't work, reinstalled 5.0.8 OTA with local update didn't work too.
    There's solution? This bug didn't appears on OOS 5.0.6
  3. MrHari_theCarguy
    Jelly Bean Jan 5, 2019
    MrHari_theCarguy , Jan 5, 2019 :
    I updated my OP3T to oxygen os 5.0.8 about 2 weeks ago,I had wiped cache from recovery after updating my phone.but for the past two days my battery is acting wierd.2 days ago I used my phone before going to bed and battery was 41%.when I woke up the next day, battery was at 22%.i put my phone on charge and it charged quickly as usual,then yesterday after some time of usage the phone was idle for some time and there was no battery drain and later when I used the phone it took like an hour for 1% drain in battery and once it does battery drained rapidly .this was happening every time I used my phone after phone was idle.pls help solve this frustrating and wierd issue as I don't think it's the problem with the actual battery but rather a software bug introduced after the latest update
  4. TechRevo
    Cupcake Jan 6, 2019
    TechRevo , Jan 6, 2019 :
    Hi guys, I have passed from Oxygen OS Beta (because there aren't new updates from July) to Oxygen OS Stable 5.0.8 on my OP3. But I noticed a great battery drain... it passes from 100% to 30% in few hours of usage.
    kashishkhanna55 likes this.
  5. Topper_Gas
    Jelly Bean Jan 7, 2019
    Topper_Gas , Jan 7, 2019 :
    What do you expect forum users to do or suggest? All you can do is trying and find out what is draining your battery, as a start have you checked your battery usage stats, if so, is one app draining the phone more than it should? Does it drain over night as well as during the day when the phone is not in use?
  6. decayed
    Donut Jan 8, 2019
  7. Q1545275038674
    Cupcake Jan 11, 2019
    Q1545275038674 , Jan 11, 2019 :
    Battery costs 1651/- including Labour. just got it changed the day before
    Shahid Hakkim likes this.
  8. J1511163650872
  9. simirad_bogdan
    Eclair Jan 12, 2019
  10. Shahid Hakkim
    Gingerbread Jan 18, 2019
    Shahid Hakkim , Jan 18, 2019 :
    How's the Battery life??
    Any Major difference?
  11. Shahid Hakkim
    decayed likes this.
  12. G_Mohd_Danish_CDGD
    Donut Jan 18, 2019
    G_Mohd_Danish_CDGD , Jan 18, 2019 :
    I have tried many things to fix this but I am unable ....
    Please give us android pie update with fixed the battery draining issue...
  13. axelon91
    Cupcake Jan 18, 2019
    axelon91 , Jan 18, 2019 :
    Today at 12:01 PM
    hi, sorry for my english...
    have change display and battery in my oneplus 3 after 1 year that the phone stay off (for dysplay craked)
    today have turn on the oneplus 3 after change display and battery, and have this problem!
    the oneplus 3 turn ON only when stay to charge; if sconnected the charge the oneplus turn-off
    when has in ON and in charge, the battery hat to 50% and "not in charge"
    the problem are the "new battery broken" or other problem?
    thanks
  14. Topper_Gas
    Jelly Bean Jan 18, 2019
    Topper_Gas , Jan 18, 2019 :
    Just getting Pie won't fix a problem with battery drain/your battery failing to hold it's charge.
  15. B1547427772428
    Cupcake Jan 19, 2019
  16. wheelie101
    Eclair Jan 23, 2019
    wheelie101 , Jan 23, 2019 :
    Hi guys,
    I'm facing the same issue today. I charged it to 100% last night and in the morning it was 91%. Since then it had drained to 55% in 10 hrs! Battery usage shows WhatsApp using most of it. I killed WhatsApp from App switcher but it continued to use in background until I forced stopped it.
    I don't use battery optimization and no optimization for WhatsApp but never faced this before. Using OP6 running OygenOS 9.0.3.
    Screen shots from battery usage.
  17. wheelie101
    Eclair Jan 26, 2019
    wheelie101 , Jan 26, 2019 :
    Receipt update from WhatsApp seems to be working fine. No more eating up my battery in the background.
  18. rban
    Eclair Jan 27, 2019
    rban , Jan 27, 2019 :
    My battery is also draining like a river it flows for that reason i need to keep my charger close . Pls do something !! or i need to chnage my battery.
    B1547427772428 likes this.
  19. Shahid Hakkim
    Gingerbread Jan 28, 2019
    Shahid Hakkim , Jan 28, 2019 :
    Guys...
    Where will i get the original battery for One Plus3T!?
    Can anybody give any links?
    I can't find which is the best one in Amazon, Flip Kart etc
    Please Help
  20. Andrei R.
    Ice Cream Sandwich Jan 30, 2019
    Andrei R. , Jan 30, 2019 :
    The original battery is only found at OnePlus services.
