4
Unified OP3/3T Battery Thread
  1. B1517575249635
    Cupcake Mar 2, 2019
    B1517575249635 , Mar 2, 2019 :
    Yes, it's correct. But the screen usage is 93 min only. I charged last night and i didn't used in night...
  2. ghostofcain
    Marshmallow Mar 2, 2019
    ghostofcain , Mar 2, 2019 :
    Are you seeing all the replies to this thread?
    Some apps run in the background draining power whether you have used them or not, one app notorious for this is UC BROWSER maybe try uninstalling it?
    Bobbie63 likes this.
  3. B1517575249635
    Cupcake Mar 2, 2019
    I installed uc browser since i bought mobile. But the draining problem is from 4 months
  4. B1517575249635
    Cupcake Mar 2, 2019
    Now Within 20 min my battery percentage reduces to 10%. Facing a big issue from 4 months.
    Sometimes i can't able to take pic in night times because of flashlight doesn't work
  5. B1517575249635
    Cupcake Mar 2, 2019
    U had also charged your mobile and i too. But u had used the screen morethan me, and here it's showing my battery % is low than yours..
  6. Bobbie63
    Bobbie63 , Mar 2, 2019 :
    Two things I notice, one is standby is high ranked, this might have to to with the reception. Second Google play services and Android is high also. I don't know when you have updated, but you might try to delete the updates from Google play services. After that, let the system update itself, don't force an update.
    Here is my reception, almost fully green
  7. P1541348373184
    Cupcake Mar 2, 2019
  8. Alexciszz
    Cupcake Mar 2, 2019
  9. Blue-agila
    Ice Cream Sandwich Mar 2, 2019
  10. B1517575249635
    Cupcake Mar 3, 2019
  11. B1517575249635
    Cupcake Mar 3, 2019
    B1517575249635 , Mar 3, 2019 :
    It's a screenshot before and after 10 min charged mobile. Facing a big issue from 4 months. Can't able to pics too. Today i have to visit for function and my mobile doesn't working in a proper way....
  12. B1517575249635
    Cupcake Mar 3, 2019
    Atleast need 60min to fully charged, but here showing as 15 min left to fully charged when my mobile is at 15%. How is it possible.....
    I'm facing an issue like this from last 4 months. I need an update
  13. B1517575249635
    Cupcake Mar 3, 2019
  14. B1517575249635
    Cupcake Mar 3, 2019
    I charged my mobile, and used it for 30min. Now battery % reduces 94% to 42% within 45min...facing an issue from 4 months
  15. B1517575249635
    Cupcake Mar 3, 2019
    resurrecti0n likes this.
  16. Horsault
    Nougat Moderator Mar 3, 2019
  17. Horsault
    Horsault , Mar 3, 2019 :
    Useless thread merged to existing one.
  18. Bobbie63
    Marshmallow Mar 3, 2019
    Bobbie63 , Mar 3, 2019 :
    Tbh, this all looks kind of weird indeed, my best opinion is the battery has come to its end. Best would be to change battery if you have such strange readings.
    If possible, I would go to a service centre and let them test the battery in a proper way. Another thing you could do first is to run your device in safe mode for a while to see what is happening.
    Also, for the time backup your important files if not done so as there might be a possibility the battery stops working suddenly.
  19. E1533905673930
    Cupcake Mar 5, 2019
  20. Topper_Gas
    Jelly Bean Mar 6, 2019
    Topper_Gas , Mar 6, 2019 :
    Before you change the battery have you tried clearing the cache and if that doesn't work try it in safe mode. Usually batteries fail gradually rather than instantly have you notice a slow deterioration?
