9
Unified OP3/3T Battery Thread
  1. TheBDrag
    Cupcake Mar 22, 2017
    TheBDrag , Mar 22, 2017 :
    have same issue since last 3days, when I updated to 7.1.1. I just did the factory def today, so let's see if that helps...
  2. James Matthew Wells
    Honeycomb Mar 22, 2017
    James Matthew Wells , Mar 22, 2017 :
    I am in the same boat. I did a reset right after flashing Beta 12. I believe this is a bug in the 7.1.1 updates (both stable and beta). I know some people report no issues, and I had none for a few days, but for the past week it has been bad. No new apps and I have no Facebook apps at all.
  3. F_Kuntal_Roy_IQcV
    Gingerbread Mar 22, 2017
  4. s.u.m.i.t
    Froyo Mar 22, 2017
    s.u.m.i.t , Mar 22, 2017 :
    but this problem is months old
    i have this issue from about a month later after i bought it
    & i have already replaced it once when i first bought it they replaced it and i got the new one but after a month it started again (which means i cant replace it as its only under 30 days ) **** man
    and im on 7.0
  5. s.u.m.i.t
    Froyo Mar 22, 2017
    yeah same here bro
  6. F_Akshay_Changal_pOxD
    F_Akshay_Changal_pOxD , Mar 22, 2017 :
    hi
    I am also having same problem battery life sucks after updating to 7.1.1 and fingerprint scanner is also slowed down.
    if anyone have some solution on it please let me know..
  7. kenny42192
    kenny42192 , Mar 22, 2017 :
    8hrs and you have 45% left ...that's more than enough for me! how long do you actually need the battery to last?
    petesin13 likes this.
  8. darius1988
    KitKat Mar 22, 2017
    darius1988 , Mar 22, 2017 :
    have you tried wipped cache from recovery , Factory reset then wipped cache again? Then have you tried calibrate the batterry?
  9. RochishnuPalit
    Froyo Mar 22, 2017
  10. G_Mathias_Acevedo_kTTI
  11. mimehta
    Froyo Mar 22, 2017
    mimehta , Mar 22, 2017 :
    I am not seeing any battery issues at all. The release seems stable so far
  12. G_Emīls_Johansens_hciq
    G_Emīls_Johansens_hciq , Mar 22, 2017 :
    same here
  13. G_Emīls_Johansens_hciq
    i know right
  14. Vikas.kasture.1982
  15. G_Emīls_Johansens_hciq
  16. jim262
    Ice Cream Sandwich Mar 22, 2017
    jim262 , Mar 22, 2017 :
    Then you should have found the answer. So why do you still complain?
  17. savvymatthew
    savvymatthew , Mar 22, 2017 :
    I'm also having battery problems. Already tried clearing cache and refreshing. I don't want to downgrade but I might for the battery life I was getting.
  18. DJDON1302
    DJDON1302 , Mar 22, 2017 :
    Indeed. the update works like charm.
  19. jim262
    I have absolutely zero issues with battery drain. It easily lasts all day for me and when I go to bed and charge device, I usually have 20-30% left, therefore this must be a user issue because there is nothing wrong with the OS.
  20. ale.comi
    Froyo Mar 22, 2017
    ale.comi , Mar 22, 2017 :
    I have the same problem. I try the solve guide without any positive result. Then i do factory reset and the problem still remain... Help..
    In the previous Version android System never consume that amount of battery
