10
Unified OP3/3T Battery Thread
  1. jim262
    Ice Cream Sandwich Mar 23, 2017
    jim262 , Mar 23, 2017 :
    Updates are created in an environment sans much of the data we have on our devices. So to obtain speeds and other benefits from the ROM, we need to emulate their environment to our best ability since it is impossible for them to emulate ours.
    It is physically impossible for a ROM to operate at 100% peak perfection as we load more and more data with more third party apps, which often start at boot and run in the background draining battery and eating up memory. That may not be the way you want a phone to work, but that is the reality. You can say what you want, but results speak even louder. I have posted many screenshots showing the type of battery life I get.
  2. s.u.m.i.t
    Froyo Mar 23, 2017
    s.u.m.i.t , Mar 23, 2017 :
    network is good here no issues
    But if i use it somewhere where there are walls closed from almost all sides there there is no network thats all
  3. s.u.m.i.t
    Froyo Mar 23, 2017
    i couldn't get the problem in this phone
    as it sometimes works perfectly fine and sometimes horrible
  4. G_Tunerz_Anthems_Frwg
    Cupcake Mar 23, 2017
  5. chirag bhatia
    chirag bhatia , Mar 23, 2017 :
    from the screenshot i figure its the network
  6. viveks_911
    viveks_911 , Mar 23, 2017 :
    mine is fine
    i get minimum 4 hrs sot with 26 hours of uptime.
    google backup,auto close or lock apps and aggressive doze off these all are disabled.
    try this it worked for me i was getting 2.5 hrs sot before.
    everything else sync and all is on.
    let me know does it help u guys.
    Amit Lko likes this.
  7. Amit Lko
    Eclair Mar 23, 2017
    Amit Lko , Mar 23, 2017 :
    same here
  8. ravish5497
    Honeycomb Mar 23, 2017
    ravish5497 , Mar 23, 2017 :
    u may be right but everytime backing up clearing data and again installation of data is not convenient..thats all i wanna say
  9. Sprograt
    Gingerbread Mar 23, 2017
    Sprograt , Mar 23, 2017 :
    I'm not having any battery issues on 4.1.0 up to now the best SOT I've had is 9H 14M, on a stock unrooted device with WiFi on permanently.
    jim262 likes this.
  10. G_Satish_Ranjan_GBHf
    Donut Mar 23, 2017
  11. dodojanik
  12. hugoface
    Donut Mar 23, 2017
    hugoface , Mar 23, 2017 :
    Yes I have the same problem. Android OS taking 20% and Android system 15% of battery since the latest update. I'm getting tired of always the same problems with battery no matter which Android phone or manufacturer.
  13. G_Danial_Javaheri_FOSE
    Donut Mar 23, 2017
  14. Yasin_Shaikh_
  15. HasratGuliyev
  16. avlysh
    avlysh , Mar 23, 2017 :
    just wait for next some battery circle itll be back n no drain issues
  17. Wahoux
    Lollipop Mar 23, 2017
    mpore14 likes this.
  18. grayfac23
    grayfac23 , Mar 23, 2017 :
    After the update it looked like I was going to get 3hrs of battery life. After a reboot the battery has lasted almost 2days. Very happy with the 3T and it's performance.
    richard_le likes this.
  19. badkone
  20. Matey Aurel
    Matey Aurel , Mar 23, 2017 :
    no problem with battery... make a factory reset ..recent my friends get update on htc after update brain battery ..problem solved after rest
