10
Unified OP3/3T Battery Thread
  1. ryangomes
    Froyo Mar 23, 2017
    ryangomes , Mar 23, 2017 :
    Accubattery say that I should get 5 hrs with my usage, which I do.
    Is this time of drain fine or should I do a factory reset
  2. Wahoux
    Lollipop Mar 23, 2017
  3. ryangomes
    Froyo Mar 23, 2017
  4. Lancelot_69
    Lancelot_69 , Mar 23, 2017 :
    Looks good, you happy with sot? If so leave it alone
  5. jim262
    Ice Cream Sandwich Mar 23, 2017
    jim262 , Mar 23, 2017 :
    C'mon, if you know what your doing, it only takes 10 minutes.
  6. ryangomes
    Froyo Mar 23, 2017
    I'm just asking if someone could tell if it's fine, I'm not complaining about the battery.
  7. naseem_hussain
    Froyo Mar 23, 2017
  8. ryangomes
    Froyo Mar 23, 2017
    yea, cause I wanted to put a 2nd sim in, wanted to know if I should do any factory resets before I do that if it was not normal
  9. Chiizis
    Froyo Mar 23, 2017
    Chiizis , Mar 23, 2017 :
    Screen very drains battery. And also Android system. This update is bad, because battery drains fast. I tried clean install, but no changes. Sucks.
  10. Chiizis
    Froyo Mar 23, 2017
  11. Wahoux
    Wahoux , Mar 23, 2017 :
    Ask on already opened battery threads.., no need to open a new one
  12. omnomnomo
    Cupcake Mar 23, 2017
    omnomnomo , Mar 23, 2017 :
    That seems fine. You might get lower than expected with games like (CoC) since it does use a bit more processing power than other apps
  13. MarcoO83
    Donut Mar 23, 2017
    MarcoO83 , Mar 23, 2017 :
    Battery drain is perfectly normal. What OS do you got at the moment?
    Consider that with a second SIM the battery drain is higher.
  14. Lancelot_69
    I would just put in the second sim and see what happens. You will get less sot because of dual Sim but you should be fine. If it is bad after then factory reset
  15. Myasak
    Froyo Mar 23, 2017
    Myasak , Mar 23, 2017 :
    Send screen shot of whole battery status
  16. F_Sari_Nelles_ozVZ
  17. F_Aleksandar_Stojiljkovi
    Gingerbread Mar 23, 2017
  18. G_Tales_Luander_qMlL
    Donut Mar 23, 2017
  19. Babblu_Arya
    Interview_Tech likes this.
  20. UKFX
    Froyo Mar 24, 2017
    UKFX , Mar 24, 2017 :
    Yep. Drain 2% per hour with everything off when on standby and I mean everything except mobile data (good signal).
    When not on standby/sleep, battery drain is still pretty poor.
    I've always complained about inconsistent battery life to OnePlus, but it is definitely worse on Nougat.
