9
Unified OP3/3T Battery Thread
  1. daninantro
    Ice Cream Sandwich Apr 4, 2017
    daninantro , Apr 4, 2017 :
    Thats weird.. Android OS and system feature battery usage reduces after a 3-4 days. After every new rom flash this drain will be high and it will reduce substantially after 3 days.
    Did you sideload the rom or just got OTA for OOS 4.1.0? I suggest u do a clean flash with twrp recovery, may help :)
    mharis likes this.
  2. aquilla
    Gingerbread Apr 4, 2017
    aquilla , Apr 4, 2017 :
    This option works, but seems not like the easiest solution, since you have to root your device.
  3. aquilla
    I think this is normal, because Android needs some time to settle. 2-3 days seem a little long but it depends on your usage.
  4. Chummy
    Cupcake Apr 4, 2017
    Chummy , Apr 4, 2017 :
    I am facing battery drain issue after 4.0.3 update. 5% drain for every 2 minutes. Any help?
  5. creed90
    Donut Apr 4, 2017
    creed90 , Apr 4, 2017 :
    here is my battery stats
    is this normal.
    also before going to sleep my battery was at 64% when i woke up it was at 54%. is this ok for standby drain.
    running open beta 13.
    Thank you
  6. Jinson Jacob John
    Cupcake Apr 4, 2017
  7. maheshzx
    maheshzx , Apr 4, 2017 :
    Nearly 14% drain over last night,using only one sim,wifi, data off.Hilariously power saving mode drains the battery more.
  8. manimaarans
    Honeycomb Apr 4, 2017
    manimaarans , Apr 4, 2017 :
    Second point is so true. If the onset of problem is just after update, they are the main culprit.
  9. BobbyV8_
    The Showcase Reviewer Apr 4, 2017
    BobbyV8_ , Apr 4, 2017 :
    Yep. Some apps are not being optimized in right way by the devs. These apps are the culprits for wake locks & running the Android system yet people blame OEM for battery drain.
    It is a simple issue & really easy to make you think "why other devices are not facing this?"
    May be because they are not having these kind of Culprit Apps installed.
  10. pgsk97
    pgsk97 , Apr 4, 2017 :
    charge ur battery to 100% before sleeping at night and leave the phone till morning. Take the phone to ur work or use ur phone like u do everyday,u can see a change in battery life.
    like this after doing that.
  11. CrEet@n
    Froyo Apr 4, 2017
    CrEet@n , Apr 4, 2017 :
    if u active all this thing wont your phone be affected it will decrease your performance of phone very much
  12. _shivamagarwal_
    Cupcake Apr 4, 2017
    _shivamagarwal_ , Apr 4, 2017 :
    yeah bro..same here!!Android system is consuming 3 times than of screen on time
  13. Murdana
  14. G_NiaVisHar_HARdeep_SAHU
    Cupcake Apr 4, 2017
  15. siddharthgpta
    siddharthgpta , Apr 4, 2017 :
    I don't play any games at all and I still get 3.5-4 hours of SOT at max. hence my annoyance.
  16. siddharthgpta
    I live in India and I can differentiate the temperature that my phones goes to from normal charging temperature. My phone was heating up like I was putting in the oven to cook it. I shifted to the OB4 now. no issues with overheating while charging now but Play Services is still sucking the life out of my battery.
  17. melwyn02
    Eclair Apr 4, 2017
    melwyn02 , Apr 4, 2017 :
    Op3 has 6gb ram coupled with SD820. Performance will certainly not be affected much.
  18. INDIANTROID
    INDIANTROID , Apr 4, 2017 :
    don't use data connectivity for a day and then check your OnePlus battery status. I believe it will help you .
  19. Shoaib1093
    Cupcake Apr 4, 2017
  20. Sau0211
    Sau0211 , Apr 4, 2017 :
    I am getting great battery life after factory reset
    6hrs sot... on heavy usage continuous wifi or 4g..
