6
Unified OP3/3T Battery Thread
  1. Bornik Bhattacharyya
    Donut Dec 27, 2016
  2. roopeshbhardwaj
    Ice Cream Sandwich Dec 27, 2016
  3. JohnJr
    Cupcake Dec 27, 2016
  4. Rollodent
    Donut Dec 27, 2016
    Rollodent , Dec 27, 2016 :
    Yep - will try to factory reset.
    Just very strange I get very fast battery consumption even while phone is at rest.
    KforHorizon likes this.
  5. Kiran.a.joseph
    Jelly Bean Dec 27, 2016
    Kiran.a.joseph , Dec 27, 2016 :
    Ensure that the NFC is switched off. Prolonged use of NFC will drain the battery and heat the mobile.
    G_Mr_.... likes this.
  6. KforHorizon
    KitKat Dec 27, 2016
    KforHorizon , Dec 27, 2016 :
    It's good that for once someone in here actually listened and tried the suggestion instead of just getting offended! Cheers mate! :) Tell me how it goes! :rolleyes:
  7. Kiran.a.joseph
    Settings => Storage & memory => Storage & USB
    Click on Cached data to clear the cache
    kiran.joseph likes this.
  8. G_Mr_....
    G_Mr_.... , Dec 27, 2016 :
    Hi I faced a few issues when i first started using it,try going through settings & turn off certain things in Google location & motion settings also, syncing, clear cache partition & try & staying away from battery draining apps.
    Hope this helps.
  9. mwolf93
    Cupcake Dec 28, 2016
  10. dothenew
    Eclair Dec 28, 2016
    dothenew , Dec 28, 2016 :
    after 121316 update battery is draining like hell. Battery backup downgrades to extreme levels.
    Any tips for optimizing battery backup?
  11. kishorkk23
    Donut Dec 28, 2016
    kishorkk23 , Dec 28, 2016 :
    Hi Guys,
    Here are some fixes which worked on my oneplus 3/3T.
    1) Wipe Cache Partition : Really effective
    • Turn the phone back on while keeping the volume down button pressed in and choose the wipe cache partition.
    2) Remove all shortcut icons from the current launcher and install Nova or any other launcher. Default launcher sucks battery.
    ----- Above things really worked for me.
    Note: Turn off these :
    NFC, Ambient display, Adaptive brightness, power save mode
  12. g_au
    Eclair Dec 28, 2016
  13. groberthsp
    Eclair Dec 28, 2016
  14. Karan_Sarraf
    Eclair Dec 28, 2016
    Karan_Sarraf , Dec 28, 2016 :
    Can you tell me how long it lasts if you use it continously?
  15. ravvarapuprithvi
    ravvarapuprithvi , Dec 28, 2016 :
    Same issue with my phone as well.
  16. dhairyac2
    dhairyac2 , Dec 28, 2016 :
    Facing the same issue. First i thought the problem was with my device but then noticed that it started after the update. Before the update it could last for 1.5 days on normal usage, 2 sims,wifi,sometimes 4g,auto brightness off. Have tried cleaning cache but no luck. Will factory reset tommorow and will let you know the result. Hope developers resolve the problem asap. My 3t's battery stats Screenshot_20161228-141534.png
  17. ZoroKoBoro
    Honeycomb Dec 28, 2016
  18. Rambo1222555
  19. ChengLongKhoo
    ChengLongKhoo , Dec 28, 2016 :
    guys, other than battery drain fast, do you facing any issue with 3T getting warmer as long u use and doesn't get cold as it is? and one more thing, what's the purpose of buying a phone while putting it into flight mode and uninstalling all memory draining apps? we would expect 3T can survive with those due to its 6gb RAM or it just nothing can used if u used up to 3 gb RAM in the phone? no point keep restarting the phone which could cause other issue like battery explosion like our Samsung and iPhone!
    dsall likes this.
  20. realslimsiddy
    Gingerbread Dec 28, 2016
    realslimsiddy , Dec 28, 2016 :
    No problems here! I'm getting 6+ hours of SOT. Moderate to heavy usage and it easily lasts for 12 hours.
