3
Unified Op3 heating issues thread
  1. G_subhash_maheshwari_euj
    Cupcake Feb 20, 2017
  2. G_subhash_maheshwari_euj
  3. rcwaghmare55
  4. shubhamsingh55
    Honeycomb Feb 20, 2017
    shubhamsingh55 , Feb 20, 2017 :
    After upgrading to 4.0.3 my PO3 is heating a lot with normal usage like while YouTubing..
    Also after update my battery is draining so fast..
    Hardly i get 3.20hrs screen on time..
    Help me..
    i hv cleared all catch files.. also onplus launcher's data..
    but nothing worked..:(
  5. mrlazydizzy
    Donut Feb 20, 2017
  6. Sheldon87
    Froyo Feb 20, 2017
    shubhamsingh55 likes this.
  7. Mizgal OP3
  8. shubhamsingh55
    no idea brother..
    U know what i was planning asphalt8 but only in 5 minutes my phone got too hot to touch..
    its very annoying yaar..
    They shouldn't release this post..
    its worst rever..
    my phone never had heating issue in past
    rafath786 and Jasraj sharma like this.
  9. Hmttorne
    Jasraj sharma likes this.
  10. Hmttorne
  11. xAphex
    Ice Cream Sandwich Feb 20, 2017
  12. G_roop_ratan_singh_uoAQ
    Cupcake Feb 21, 2017
    G_roop_ratan_singh_uoAQ , Feb 21, 2017 :
    same with my device
    ...even called one plus customer care around 20-25 times till now....they advised me to submit my phone to the care centre but they don't take the phone and they say that for heating issues they just reinstall the software...but it's doesn't work ....I m fed up now ....try to give your phone to care centre
  13. G_Chethan_G_S_JDDZ
  14. Narender
    Eclair Feb 21, 2017
  15. JexTWO
    JexTWO , Feb 21, 2017 :
    I found when my phone has done this the last few updates I got it fixed by:
    1. Reset all app permissions
    2. Basically letting every Google app get EVERY permission it wants and doing the same for all the stock apps.
    3.(optional) If you don't like the Google and stock apps on your phone having all those permissions, start reducing them little by little until you run in to the overheating/battery draining issue again.
    This did it for me without me even having to factory reset my phone after the Nougat OTA and the more recent one.
    It was all about some app trying to using a permission it didn't have and getting stuck in a loop because the app already thought it had the permission.
  16. Ayush_09k
  17. G_guntha_Sandeepgupta_TE
  18. G_guntha_Sandeepgupta_TE
  19. Niku67
  20. Mizgal
    Mizgal , Feb 21, 2017 :
    Wipe cache and factory reset does'nt work at all - should i roll back to 3.5.5 ? Do i need to wipe all data from phone?
    Any officcial support from OnePlus?
    nizklaz likes this.
