3
Unified Op3 heating issues thread
  1. G_Chinmay_bapat_oQMj
    Ice Cream Sandwich Feb 23, 2017
    G_Chinmay_bapat_oQMj , Feb 23, 2017 :
    random heating is a problem ever since the nougat update I guess... and also the battery life had deceased by about 10_20%.. Nougat effect as well acc to me..
  2. Vinoth Prabakar
    Cupcake Feb 23, 2017
    Vinoth Prabakar , Feb 23, 2017 :
    same problem
  3. G_Minhazul_Islam_Kolm
  4. F_VįNų_ChaNdran_sHlC
    Cupcake Feb 24, 2017
    F_VįNų_ChaNdran_sHlC , Feb 24, 2017 :
    After updated Oxygen 4.0.3 too much of Heating the phone.do not on the data usage that time also mobile is heated. and battery also fastly drain. What to do????
    sai_spartans likes this.
  5. ankit3vedi
  6. Mayur.chandan
    Donut Feb 24, 2017
    Mayur.chandan , Feb 24, 2017 :
    I regret the inconvenience caused to you, this is to inform you that OnePlus device comes with Qualcomm snapdragon processor and it produces heat when it runs in the background. It is normal and will not affect the device or its health.
    However, I would request you to please follow the below mentioned troubleshooting for heating issue.
    Heating issue:
    1. Turn off unusable functions, exit the camera, reduce the screen brightness and shorten the time of the screen lighting.
    2. Clean up the background running process, download software or games in official store, upgrade the software or application to the latest version.
    3. Cleaning up the cache regularly and keep enough space.
    4. We recommend you to avoid using the device while charging.
  7. G_huw_roberts_JyZG
  8. sai_spartans
    Eclair Feb 24, 2017
    rafath786 likes this.
  9. F_ER_Aadil_Chogle_YXRG
    Froyo Feb 24, 2017
  10. nifty_mats
    Donut Feb 24, 2017
    nifty_mats , Feb 24, 2017 :
    Have u tried cache wipe?? Try it and see.
    Basically, switch off ur fone. Restart by pressing Volume up+power+home button.
    This will get u to the Recovery menu. Go to cache wipe by pressing the volume key. And select cache wipe by pressing power key. That's it..
  11. G_Patel_Divy_NSoG
  12. Harmibder Singh
  13. niravdhanorkar
    niravdhanorkar , Feb 24, 2017 :
    facing same issue of faster battery down, but after seen my battery usage, i came to know that truecaller is having main issue. so i uninstall
    now battery working long.
  14. rafath786
    Gingerbread Feb 24, 2017
    rafath786 , Feb 24, 2017 :
    Yes, after cleaning cache and made reset factor for multiple times but no improvement
  15. HermitDash
    Honeycomb Feb 25, 2017
    HermitDash , Feb 25, 2017 :
    Check your apps, there might be one that's causing major battery drain. If not try doing a factory reset or reflash the rom.
  16. Rama gangadhar
    Donut Feb 25, 2017
  17. harry_db
    Gingerbread Feb 25, 2017
    TweakIt and zoestar like this.
  18. zoestar
    Lollipop Feb 25, 2017
    zoestar , Feb 25, 2017 :
    Yep. What's normal use?
  19. Reebu Rawat
    Eclair Feb 25, 2017
  20. zoestar
