3
Unified Op3 heating issues thread
  1. vickram
    Gingerbread Apr 13, 2017
    vickram , Apr 13, 2017 :
    Me too having the same issue, while simply the charging....not even surfing or playing games.... [e]1f4f1[/e] start [e]1f525[/e] while changing.....
  2. jatingada
    jatingada , Apr 13, 2017 :
    bc naya update aaya nai ke problems chalu. yeh log such mein update karte hai ya chu..... banate hai
    G_dhaval_shinde_ZupO likes this.
  3. divinityQQ
    Honeycomb Apr 13, 2017
    divinityQQ , Apr 13, 2017 :
    Just let it to settle down, it takes some time in Nougat since apps are being optimized in the background, so you don't have to wait for them to optimize at the first boot.
  4. Sagar.aman1021
    Sagar.aman1021 , Apr 13, 2017 :
    even experiencing low volume from bottom speaker be it ringtone video audio or songs compared to last build that it 4.1.1
  5. Sagar.aman1021
    normally using and simple browsing YouTuber
  6. Sagar.aman1021
    wait for next update or roll back to 4.1.1
    anirudha_v_bharadwaj likes this.
  7. Deactivated User
    Apr 13, 2017
  8. G_amm_t_(ammt)_UDLG
    shyamjajoo likes this.
  9. Shinderahul910
    Cupcake Apr 13, 2017
  10. Abhyaung
    Abhyaung , Apr 13, 2017 :
    I am too having the problem of getting hot.
    while charging I'm idle condition the charger and the mobile both get very hot as are getting explode.
  11. bez54
    Eclair Apr 13, 2017
    bez54 , Apr 13, 2017 :
    all good here. check to see if you have a shitty app running wild. it could be something in the background. Facebook usually is the problem. it's the worst app ever. once i deleted it and got an extra 25% battery back and no heat.
    F_Sasi_Sd_LInC likes this.
  12. G_Srikanth_Babu_CNym
  13. G_Dee_Scheepers_xjrZ
    Eclair Apr 13, 2017
    G_Dee_Scheepers_xjrZ , Apr 13, 2017 :
    Yes I have this issue too, I have this over heating issue when I am just about the town and carrying the phone in my pocket... It scares me, started carrying it in my back pack is it sometimes feels like it's burning me it gets that hot... I am beginning to feel a bit disappointed with this near £350 purchase...
  14. F_ER_Aadil_Chogle_YXRG
    Froyo Apr 13, 2017
  15. SimonRam
    Lollipop Apr 13, 2017
  16. robogo
    robogo , Apr 13, 2017 :
    For the millionth time:
    - factory reset or clean flash your phone
    - go through the initial setup
    - DO NOT download any apps
    - let the phone sit for 20-30 minutes after flashing, don't touch it, don't look at it.
    If it's hot when you pick it up, it's faulty. If it gets hot after you restore your apps, it's an app causing trouble. If it's hot even after clean flashing a non-Oxygen OS ROM, it's the phone and you should send it in for service.
  17. Sagar.aman1021
    and before posting it.. you should read that i have done everything i m noob. yea will do clean flash. most probably corrupt OS. thanks. :)
  18. G_Sergio_Calvo_LKEF
  19. Two Plus
    Gingerbread Apr 14, 2017
    Two Plus , Apr 14, 2017 :
    The update has only been live for I think less than 24 hours, the phone might need more time to balance out like how it usually works with the charging? Run it through a few cycles and then it regulates?
    Maybe I'm wrong. Just a thought
  20. F_Diganta_Koner_WIXu
    Jelly Bean Apr 14, 2017
