5
Unified Op3/T heating issues thread
  1. Madhav Jani
    Cupcake May 9, 2017
  2. TheTechGuru
    Froyo May 9, 2017
    TheTechGuru , May 9, 2017 :
    Given the phone has an aluminum design, and metal conducts heat, I'd say your phone has a serious issue.
  3. flo_90
    Froyo May 9, 2017
  4. fung11
    Cupcake May 10, 2017
    fung11 , May 10, 2017 :
    i think your battery have problem, for your safety try to contact their customer service to check about it
  5. Heisenberg_009
    Ice Cream Sandwich May 10, 2017
    Heisenberg_009 , May 10, 2017 :
    Wait, device gets hot when charging and battery drops at the same time? Do you use apps like facebook, fb messenger or play games while charging your phone?
  6. MafiaTechTeam
    Jelly Bean May 10, 2017
    MafiaTechTeam , May 10, 2017 :
    do you have no concept on how this shit actually works?
    your phone CANNOT be lower than ambient temperatures
    SAY ambient temps are 40c YOUR phone will be ATLEAST 40c
  7. humanzqzr
    Honeycomb May 10, 2017
    humanzqzr , May 10, 2017 :
    If anyone is living in countries where there is summer season going on like India it's a normal because of atmosphere temperature is close 40°C and hence the phone will feel warm because metal is good conductor of heat. In Winter season you will feel the phone is cold.
  8. VaibhavBhargava
    Lollipop May 10, 2017
    VaibhavBhargava , May 10, 2017 :
    As long as battery isn't heating up, it shouldn't be an issue. The processor will automatically slow down if excess heats builds up, to prevent thermal runaway.
  9. elanglois
    elanglois , May 10, 2017 :
    Don't tell people shit like that. They might be dumb enough to try it
  10. elanglois
    Those temps are normal unless your phone is idle or under light usage. Likely, you have a lot of apps checking up on you, pushing analytics to web servers and checking for push notifications.
    But 40 isn't hot by any means
    Aditya_Rathore likes this.
  11. F_Diganta_Koner_WIXu
  12. Baibhav_Kumar
    Baibhav_Kumar , May 10, 2017 :
    Yeah I too face overheating issue while charging my phone . So I try to charge it in small packs at a time not fully charging it in one go because then my phone becomes very hot ( like I can't talk with anyone on phone without burning my ear).Hope op fixes this issue soon .
  13. pcoventry
  14. G_abhinav_gupta_SHeJ
    G_abhinav_gupta_SHeJ , May 10, 2017 :
    I having problem with phone 3T regarding its heating ..Purchase it on 8 may 17.Whenever I play heavy games or surf it gets heated.Any suggestion how can I lower it down.
  15. Tobikage
    Nougat May 10, 2017
    Tobikage , May 10, 2017 :
    Exactly. That's the point.
  16. gnu101
  17. G_Melfice_Moon_xCwS
    Froyo May 10, 2017
  18. soomab
  19. mayank1984
    Eclair May 10, 2017
    mayank1984 , May 10, 2017 :
    plz live with it there no solution to this prb..nobody can give you answer for this....
  20. KRISHANU SINGH
    Gingerbread May 10, 2017
    KRISHANU SINGH , May 10, 2017 :
    Sorry bro but no phone works the way u think it works, even if u buy S8+ or LG G6 or iPhone 7 u will face these issues as long as u don't take care of the device. Any device either being android or ios needs a reset after a major big update for proper functioning. Rest is your wish and your money. Don't blame the company.
