5
Unified Op3/T heating issues thread
  1. GopalB.
    Nougat Nov 22, 2017
  2. pradeepmardia
    Donut Nov 22, 2017
    pradeepmardia , Nov 22, 2017 :
    what are you doing dude
    we are talking about oxygenOS Not Android Os
  3. GopalB.
    Nougat Nov 22, 2017
    GopalB. , Nov 22, 2017 :
    But you are still on older ver...
  4. pradeepmardia
    Donut Nov 22, 2017
    Yes
    you received newer version?
  5. GopalB.
    Nougat Nov 22, 2017
    I'm op5 user...
    So we are not the fortunate ones...
    You can wait...
    Or try canada vpn...
    pradeepmardia likes this.
  6. pradeepmardia
    Donut Nov 22, 2017
    You are Right in A way but its Oneplus's Problem they knew that its going to heat this much but they still used metal body now because of them im facing this issue
    ITS NOT LIKE SETTLE WITH IT "NEVER SETTLE"
    i know we can't do anything now but at least we can Tell OnePlus that this is happening just because you focused more on looks then customers comfort
  7. Deatham
    Ice Cream Sandwich Nov 22, 2017
    Deatham , Nov 22, 2017 :
    metal is not for looks, it's for solidity and strength, plastic is plastic, right? and glass is just too fragile.
    so a huge majority on smartphone users prefer metal unibody over other materials.
  8. pradeepmardia
    Donut Nov 22, 2017
    what about the ceramic type they used in OnePlus one
  9. Deatham
    fragile. again. and expensive.
  10. pradeepmardia
    Donut Nov 22, 2017
    i don't think its fragile my brother using it from launch but still no problem.
  11. pradeepmardia
    Donut Nov 22, 2017
    but Still there are so many other phones with same processor and all but they are not getting heat
    and yeah they are more expensive then OnePlus but still
  12. A1508076264338
    Donut Nov 23, 2017
    anz563 and Daniel Hee like this.
  13. Spikester316
    Eclair Nov 23, 2017
    Spikester316 , Nov 23, 2017 :
    do u mean your phone is getting hotter during use since Oreo? mine too dunno why. try to not use battery saver and just use it normally maybe that'll help as I usually have battery saver on most of the time.
    Daniel Hee likes this.
  14. N1510986064546
    Eclair Nov 23, 2017
    N1510986064546 , Nov 23, 2017 :
    it's a issue of Oreo because I'm using battery saver on nougat and don't get hot l, I'm downgrade from Oreo by so many bug ...
  15. Spikester316
    Eclair Nov 23, 2017
    yeah mine didn't get hot on nougat either what I'm saying is for whatever reason Oreo is needing more CPU power at this moment in time so if we turn off battery saver then the CPU won't be bottlenecked and hopefully the device won't overheat as frequently. . do u understand what I mean now?
  16. Singh is Kinng
    Gingerbread Nov 23, 2017
    Singh is Kinng , Nov 23, 2017 :
    After upgrading to Oreo have you done a Factory Reset?
    Also, you need to give it time to settle.
    There is always an embedding period after an upgrade.
  17. M Surendra_suri_koQl
    Cupcake Nov 23, 2017
    M Surendra_suri_koQl , Nov 23, 2017 :
    i use jio 4g voice app for calls...via wifi ..as i use jiofi device. recently from past 15days i observed my one plus 3t is heating up ,the moment i open jio 4g voice app.dont know weather its app issue or phone issue.when i close the app .phone temprature starts going down..please help me out
  18. pullaredddy
    Donut Dec 14, 2017
    pullaredddy , Dec 14, 2017 :
    yeah.. my op3t is heating up while charging after Oreo update... while normal usage it's not heating up...
  19. nanduop3
    Cupcake Dec 14, 2017
    nanduop3 , Dec 14, 2017 :
    hi team my phone op3 is heating up and battery draining out very fast after updating to Oreo. pls help
