5
Unified Op3/T heating issues thread
  1. G_Bobby_Teja_kDXx
    Donut Feb 18, 2017
    G_Bobby_Teja_kDXx , Feb 18, 2017 :
    I upgraded to A3003_28_170208 yesterday.
    now my mobile is heating up using after 4-5 mins.
    Android system also draining battery.
    plz help.
  2. G_Bobby_Teja_kDXx
    Donut Feb 18, 2017
    kartiiks likes this.
  3. G_Raj_Prajapati_YDLk
    Cupcake Feb 18, 2017
    G_Raj_Prajapati_YDLk , Feb 18, 2017 :
    I don't know what is the problem with my oneplus 3t it again started heating up ideally. So i reset everytime but after a week it started heating up ideally agian. SO PLEASE GIVE ME A PERMANENT SOLUTION.
  4. OnePlusShreyas
    Gingerbread Feb 18, 2017
    athaarv and Jasraj sharma like this.
  5. G_Raj_Prajapati_YDLk
    Jasraj sharma likes this.
  6. DagLeonardsson
    DagLeonardsson , Feb 18, 2017 :
    I have issues au Well. Battery drop 5-10% in night with no use, location deactivaded ( before this update location was always on and I had no problems whatsoever) . And I have to charge it Once à Day now compared to once envery 36 hours before this update. I haven't noticed any heat related problem but maybe there are some. I'll pay attention to That.
    =( is there any way to go back to previous update without rebooting and erasing the contents of my phone ?
    I am writing this from my phone and just lost 5% more battery.
    NEED HELP please oneplus do something !
    nazaby and himanshusaxena0001 like this.
  7. G_Chetan_Srivastava_oABh
    G_Chetan_Srivastava_oABh , Feb 18, 2017 :
    I had same issue. I went to service center & got build upgraded again. It solved issued after full battery charge....
    Remember to take full backup before you go to service center bez they erase & copy build..
    IT worked for me. Do try it out. Should help..
  8. G_Chetan_Srivastava_oABh
  9. vallabh budhkar
  10. mouliyvn
    mouliyvn , Feb 18, 2017 :
    My phone also is draining battery very fast after the Nougat update. i am having to charge 3 times a day.
    Dont know how to make up for this behavior
  11. kartiiks
    Eclair Feb 18, 2017
    salim07862294 likes this.
  12. G_Rasool_Hyder_HgkE
  13. MC013
  14. Android450
    Marshmallow Feb 18, 2017
    Android450 , Feb 18, 2017 :
    Have all of you done a factory reset after the upgrade because if you haven't I highly recommend that you do so. (Don't tell me that it shouldn't work that way, that's how Android has always been after big upgrades)
    SachinTS likes this.
  15. G_Bobby_Teja_kDXx
    Donut Feb 18, 2017
    my location off and wifi search fr nearby is also set to never. location. is set to GPS only BT still my wifi turn on auto.... can't figure how to resolve it.
  16. G_Bobby_Teja_kDXx
    Donut Feb 18, 2017
  17. Ashwinmhatwalne
    Eclair Feb 18, 2017
    Ashwinmhatwalne , Feb 18, 2017 :
    I too have battery issues
    battery drains overnight without usage(5-10%)
    and the phone heats after some usage(oneplus 3t)
  18. G_Atish_Warankar_Cqyz
  19. G_Atish_Warankar_Cqyz
  20. Kiran.a.joseph
    Jelly Bean Feb 18, 2017
    Kiran.a.joseph , Feb 18, 2017 :
    Can you please confirm if you have done the following
    Disable auto backup
    Disable "use itineraries from gmail" in playstore settings
    Disable nfc, mobile data, wifi, bluetooth and location when you are not using it
    Disable wifi and bluetooth scanning
    Enable app auto-launch
    Enable aggressive doze mode
    Enable auto brightness
    Restart into recovery mode and clear the cache
