5
Unified Op3/T heating issues thread
  1. Rushiljoshi
    Eclair Feb 26, 2017
  2. nitinmehta96
    Eclair Feb 26, 2017
    nitinmehta96 , Feb 26, 2017 :
    Here is my phone's battery usage..
    thx..
  3. Xavier corera
    Cupcake Feb 26, 2017
  4. F_Meng_Hour_tggp
    Donut Feb 26, 2017
    F_Meng_Hour_tggp , Feb 26, 2017 :
    but i already update to 4.0.2 and it still heat up
  5. nitinmehta96
    Eclair Feb 26, 2017
    thx for sharing the link.. is there a way to downgrade to 4.0.2?
  6. nitinmehta96
    Eclair Feb 26, 2017
    can it be done without visiting the center?
  7. BharathNaik
    Eclair Feb 26, 2017
    BharathNaik , Feb 26, 2017 :
    Am also facing similar problem with my 3T.maybe they fix it with 7.1 in all in one update, or may go for 4.0.4 of they go.
  8. F_Meng_Hour_tggp
    Donut Feb 26, 2017
    OP3t is heating up too much while online and gaming. other more, the bluetooth and wifi service is poor. any idea please recommend me. i hope company will solve this problem.
  9. darius1988
    KitKat Feb 26, 2017
    darius1988 , Feb 26, 2017 :
    wipped cache:
    Turn off the phone
    Then press power boton and volume down and keep holding til vibrates
    Next chose english
    Then wipe data and cache
    Then make sure you chose wipe cache
    Yes
    Reboot
    nitinmehta96 likes this.
  10. darius1988
    KitKat Feb 26, 2017
    Then go to settings-batterry-3 dots right corner-second opcion-turn on, then reboot. Then do full cicles of charging-discharging batterry. If the problem persist then Factory reset , wipped cache from recovery , 3 dots, 2 full cicles.
  11. nishkarsharma
  12. nishkarsharma
  13. Shahriar.Rafii
    Eclair Feb 26, 2017
  14. siva_adithya
    Donut Feb 26, 2017
    siva_adithya , Feb 26, 2017 :
    I think it can be done
  15. nazeer561
    Eclair Feb 26, 2017
  16. nitinmehta96
    Eclair Feb 26, 2017
    cheers! let me try and post whatever I get..
  17. nitinmehta96
    Eclair Feb 26, 2017
  18. Batfink32
    Ice Cream Sandwich Feb 26, 2017
    Batfink32 , Feb 26, 2017 :
    I just posted a thread about this. The CPU usage on my 3T sometimes spikes and sticks at 80-90,the phone heats up, starts to thermal throttle heavily and drains battery fast. A reboot solves it for me but there seems to be some sort of bug causing this. Keep a check on your CPU usage and if it starts to spike and heat up then reboot your phone.
  19. athaarv
    Jelly Bean Feb 26, 2017
    athaarv , Feb 26, 2017 :
    I uninstalled Facebook and Messanger yesterday and there is a massive improvement in battery already
    I can't talk about the heating issue as of now. will update after a few days
  20. tonyshixd
    Froyo Feb 26, 2017
    tonyshixd , Feb 26, 2017 :
    Same here, I was freaking out. But then the static disappeared
