5
Unified Op3/T heating issues thread
  1. Master_TC
    Jelly Bean Feb 28, 2017
  2. siva_adithya
    Donut Feb 28, 2017
    siva_adithya , Feb 28, 2017 :
    I tried factory reset.. It dint made any difference.. Cause the system appps are those which consume more. Power and heat up
  3. G_Devan_Ragul_tNKO
    Cupcake Feb 28, 2017
    G_Devan_Ragul_tNKO , Feb 28, 2017 :
    Even from the date of purchase, I feel too much heat from the device. Even in light usage of browing or in whatsapp, the temperature app shows 39 degree. Can I ask for replacement or I could fix the issue?
    G_durdana_irshad_eIDU likes this.
  4. toastytoast1234
    Marshmallow Feb 28, 2017
    toastytoast1234 , Feb 28, 2017 :
    After every 30 mins of use, put it in the freezer for 10 mins to bring it back within acceptable operational parameters.
    illuminarias likes this.
  5. Machorahul
    Honeycomb Feb 28, 2017
  6. Strikeblaze
    Eclair Feb 28, 2017
    Strikeblaze , Feb 28, 2017 :
    the one plus 3/3t can heat if your charger is not dash charging it.So while charging ensure it. shows dash charging symbol.
  7. Strikeblaze
    Eclair Feb 28, 2017
    and then throw it after someday.The glorious S7 lags even in simple transitions.
  8. TweakIt
    TweakIt , Feb 28, 2017 :
    It's probably your personality that's too hot for the phone to handle.
  9. Maddyson3x
  10. elanglois
    Lollipop Mar 1, 2017
    elanglois , Mar 1, 2017 :
    Open battery settings and see what app is at the top of the list using the most juice. It's not Camera by NY chance is it?
  11. Visweshwar
    Cupcake Mar 1, 2017
  12. nitinmehta96
    Eclair Mar 1, 2017
    nitinmehta96 , Mar 1, 2017 :
    thats bad.. I'm not too eager to factory reset my phone either.. would rather wait for the next update..
  13. Linda King
    Cupcake Mar 1, 2017
  14. G_sumit_azad_sMQC
    Froyo Mar 1, 2017
    G_sumit_azad_sMQC , Mar 1, 2017 :
    same issue also here fone get overheated even in ideal conditions and battery drain very fast even with aggressive doze mode is on....
    the Android system consuming more battery.
  15. Gray . Jun
    Cupcake Mar 1, 2017
  16. Jay Arya
    Cupcake Mar 1, 2017
  17. Jay Arya
    Cupcake Mar 1, 2017
  18. OzzyJay
    Ice Cream Sandwich Mar 1, 2017
    OzzyJay , Mar 1, 2017 :
    Certain apps can do that, kill the apps and see how you go :)
  19. Deactivated User
    Mar 1, 2017
  20. siva_adithya
    Donut Mar 1, 2017
    siva_adithya , Mar 1, 2017 :
    Factory reset won't work.. It's the system app causing heating
    deepee1544 likes this.
