5
Unified Op3/T heating issues thread
  1. CeeTeePee
    Gingerbread Apr 9, 2017
    CeeTeePee , Apr 9, 2017 :
    this happened to my op3 a couple times before. I just restarted it and then it was working fine.
  2. Ambooj257
    Cupcake Apr 9, 2017
  3. G_shiva_shankaran_iVnU
    Cupcake Apr 9, 2017
  4. Brandon LI
    Froyo Apr 9, 2017
  5. G_Mohammed_Salih_aLGa
    Cupcake Apr 9, 2017
  6. anirudhkalyan19
  7. G_Ajay_Panigrahi_dIGd
    Donut Apr 9, 2017
    G_Ajay_Panigrahi_dIGd , Apr 9, 2017 :
    how to check proximity check
  8. Kiran.a.joseph
    Jelly Bean Apr 9, 2017
    Kiran.a.joseph , Apr 9, 2017 :
    Settings >> Display >> Proximity wake
    if you dont know the exact navigation, you can also search for "Proximity wake" or any other keyword in settings
  9. noquarter
    Lollipop Apr 9, 2017
    noquarter , Apr 9, 2017 :
    Merged with your previous thread
  10. KRISHANU SINGH
    KRISHANU SINGH , Apr 9, 2017 :
    While charging clr all apps from memory. Take the phone out of the cover and place the phone with the back part facing upwards. Always charge the phone where thr is circulation of cold air. Heating while charging happens to all phones specially in summers. Yesterday my phone heated to a very high temperature because i didn't switch on the fan while it was charging. Also perform a reset if possible.
  11. Shahid9900
    Donut Apr 9, 2017
  12. rakesh919
    Cupcake Apr 9, 2017
    rakesh919 , Apr 9, 2017 :
    I have the same issue but no solution till now. also it takes 8-9 hours to 100% charge
  13. rakesh919
    Cupcake Apr 9, 2017
    Android system and Android os has the most percentage
  14. Shahid9900
    Donut Apr 9, 2017
    Shahid9900 , Apr 9, 2017 :
    then.. clear cached data under storage.
    clear data in play services under apps in settings.
  15. G_T_de_jong_Fxdx
    Cupcake Apr 9, 2017
  16. Tech&Hobby
    Cupcake Apr 9, 2017
    Tech&Hobby , Apr 9, 2017 :
    My 3T still feels faster and solid after 4.1.1(7.1.1). No heat or battery drain here. Did a dubbel Celar/Clean install after update..and works like a charm..
  17. ido1526
    Cupcake Apr 9, 2017
  18. kravit
    Cupcake Apr 9, 2017
    kravit , Apr 9, 2017 :
    same here
  19. F_Junaid_Khan_kKSE
    Honeycomb Apr 9, 2017
  20. Kaustubh Marudwar
    Cupcake Apr 9, 2017
    Kaustubh Marudwar , Apr 9, 2017 :
    I faced the same issue. They said it was software issue. Format your phone at your place. This is what they did with my phone.
