257
  1. djarish
    Gingerbread May 22, 2018
    djarish , May 22, 2018 :
    Admin edit:
    To help us better resolve battery/heating-related issues, please submit a bug report [HERE]. Thank you in advance.
    Moderator edit:
    1. Please use this thread for any issues, questions, tips and all things related to battery and heating.
    2. You can ask a moderator to pin a post with battery tips to be shown on the first page of this thread.
    it's just 10 mins that I have unboxed one plus 6.
    in just 10 mins it's heated and I can feel the warmth in my hands.
    Is this a normal thing with oneplus or just happened to me ???
  2. gaurav.malhotra
    Honeycomb Jun 25, 2018
    gaurav.malhotra , Jun 25, 2018 :
    I was also facing issue like battery drain, sound bass not upto expectation, etc.
    I did a download of 5.1.8 from support ->> download section.
    saved it on root directory of storage ->> cleared cache from recovery >> installed 5.1.8 again with local upgrade (no factory reset done, no data loss) >> cleared cache again from recovery.
    happy to say battery is back to normal after a charge cycle, sound in earphones is perfect as it was on 5.1.8, face unlock is quick again,
    give it a try.
    edited: to add the process
    download file from OnePlus website, below is the link.
    Updating the link with 9.0.2
    http://oxygenos.oneplus.net.s3.amaz...2_OTA_027_all_1810260000_bbefbe028ace46e5.zip
    Step 1: download the file.
    Step 2: move file from download folder to Storage > Internal Storage directory.
    Step 3: Go to recovery and wipe cache (Search the forum in case you need help in reaching recovery).
    Step 4: Reboot the device.
    Step 5: Go to settings > System Update.
    Step 6: Select settings icon (top right corner).
    Step 7: Select local upgrade.
    Step 8: Select the downloaded file and start the update.
    Step 9: Follow the instructions and Reboot.
    Step 10: Repeat step 3.
  3. taiyou94
    Froyo Jul 14, 2018
    taiyou94 , Jul 14, 2018 :
    for battery performance, some settings u can try, i can easily get a full day means min. 24 hrs. with 7-8 hrs. of screen on time. Really Guys, and yup, 5% battery is still remains.
    1. Use dark theme.
    2. Use battery Optimisation enable for all Apps.
    3. Use deep clear in Setting->Advanced->Recent App Management->Deep Clear.
    4. No extra UI App and can also use a dark wallpaper for both home and lock screen.
    5. Face Unlock-> I dont think of its much use, also not very secure. Its always run in background and eating Ram and battery, so u can also disable it.
    Just try this guys, u can easily get 8 hrs. screen on time in full day Battery usage.
    I hope it might helps.
  4. damnitjoshua
    Gingerbread Aug 28, 2018
    damnitjoshua , Aug 28, 2018 :
    I've found a way to dramatically improve battery life on the OnePlus 6 by accident. As many of you know, battery life has gotten worse on 5.1.11 for many, including me. I've tried various methods including installing (Greenify), turning off certain features, etc.
    Last Wednesday, I turned on Data Saver because my quota was almost due. Since then, I've noticed significant battery improvements. I've been observing just to make sure that the results I'm getting are consistent before making a claim, and it did. Standby battery usage is now a 1 to 2 percent drop as supposed to 9 to 10 percent at a time spend of 7 to 8 hours. Screen on time has also improved by more than an hour.
    So for those struggling with battery life on 5.1.11, try this. A little disclaimer though, I can't guarantee this will work for you as well as it did for me cause you know, there's a lot of different factor that come into play when it comes to battery life.
    Reldin, iamrj, Illegalfall and 21 others like this.
  5. dsmonteiro
    OnePlus Community Team Staff Member May 22, 2018
    dsmonteiro , May 22, 2018 :
    Hi @djarish,
    I just moved your thread to OnePlus 6 General Support category.
    It's normal that a smartphone gets warm to the touch when the processor is doing lots of tasks, like it happens during the setup. You can try installing an app that shows the CPU temperatures, like CPU-Z, if you want to be on the safe side.
  6. djarish
  7. dsmonteiro
    You can share a screenshot of the thermals here.
  8. djarish
  9. dsmonteiro
  10. djarish
  11. Arjunan1996
    Eclair May 22, 2018
    Arjunan1996 , May 22, 2018 :
    OnePlus 6 battery drains faster don't know why today only I got the device and charged it to 100 and it is now in 78 screen usage is less than an hour very bad 1526994799591.jpg
  12. the_o2
    OnePlus 9 Series Expert Community Expert May 22, 2018
    the_o2 , May 22, 2018 :
    Posting screenshot of battery usage is always helpful for people here, how does we know that which app is eating your battery..
    E1535876388860, iamrj, PRAN25 and 4 others like this.
  13. Arjunan1996
    Eclair May 22, 2018
  14. the_o2
  15. Arjunan1996
    Eclair May 22, 2018
    no bro I'm not using it continuously but the battery is getting drained I never had this issue with my op5
  16. Arjunan1996
    Eclair May 22, 2018
  17. the_o2
    Have you gotten any updates recently..
    E1535876388860 and iPhone5lol like this.
  18. Arjunan1996
    Eclair May 22, 2018
    there was an update after unboxing the device and I updated it
  19. the_o2
    iPhone5lol likes this.
  20. the_o2
    have you restarted your phone since..
  21. Arjunan1996
    Eclair May 22, 2018
    the graph look normal but without using any app it's getting drained
    E1537719782236 and iPhone5lol like this.
  22. Arjunan1996
    Eclair May 22, 2018
  23. the_o2
    Apart from face unlock everything looks fine to me..
    let's settle down the phone it will be fine, try to charge completely after its goes below to 20%.
    Damonp87, doggo and iPhone5lol like this.
