196
  1. BRAD FORD BOI
    Gingerbread Jun 5, 2018
    BRAD FORD BOI , Jun 5, 2018 :
    boot animation on my OnePlus 6 is laggy/choppy is anyone facing the same ? any way to fix this ?
  2. dermot33
    Ice Cream Sandwich Jun 5, 2018
    dermot33 , Jun 5, 2018 :
    I thought my OnePlus 3 battery had degraded over the years,but got my op6 today and battery life is more or less the same.
    Terryruiz likes this.
  3. BRAD FORD BOI
  4. manuel19
    KitKat Jun 5, 2018
    manuel19 , Jun 5, 2018 :
    this year
  5. Terryruiz
    Terryruiz , Jun 5, 2018 :
    Any time after the 15 day return period ends !!!
    manuel19 likes this.
  6. F1528235674466
    Cupcake Jun 5, 2018
    F1528235674466 , Jun 5, 2018 :
    yes ....same here
    Srkvasista likes this.
  7. REAL6
    Cupcake Jun 5, 2018
    REAL6 , Jun 5, 2018 :
    One thing I want to know with people and their drain issue. Are you rooted or non rooted? Are you using any apps to help with the drain?
  8. M_Mohammed_Swalih_aMLp
    Cupcake Jun 5, 2018
  9. Josh PD
    Cupcake Jun 5, 2018
    Josh PD , Jun 5, 2018 :
    download a battery app and see what temp it's getting too, they do get quite warm when there used it's normal
  10. Photoman9988
    KitKat Jun 5, 2018
    Josh PD likes this.
  11. M_Mohammed_Swalih_aMLp
    Cupcake Jun 5, 2018
  12. iLogged
    Eclair Jun 5, 2018
  13. Hydra Bob
    Starting Point Expert Jun 5, 2018
    Hydra Bob , Jun 5, 2018 :
    What is the temperature of the device, what is the ambient temperature when this is occurring and what applications are you using/activities are you performing when this happens?
  14. Lorde Voldmort
  15. M_Mohammed_Swalih_aMLp
    Cupcake Jun 5, 2018
    M_Mohammed_Swalih_aMLp , Jun 5, 2018 :
    don't know how much temperature...but I feel it in back cover also.. but the temperature is very high.. it's heat's while charging & using camera..
  16. Tbestie
    Cupcake Jun 5, 2018
    Tbestie , Jun 5, 2018 :
    so my device is running cool even whilst playing games and charging. I would get your device checked if it is running hot... doesn't seem right to me.
  17. devoncatt
    Gingerbread Jun 6, 2018
    devoncatt , Jun 6, 2018 :
    My problem is it drains the battery about 25% while I am sleeping and unless I am using the phone or my cat is I am not sure what is active other than Gmail. Is there any easy way to check this? During the day it's okay I am getting about 8 hours in normal use.
  18. devoncatt
    It takes about 30 mins to get from almost empty to 60% and then slows down dramatically for the rest. But from greater than 60 % and when I charge to 95% it takes about 30 to 40 minutes
  19. G_G_wz_(GWZ)_VWBr
    Froyo Jun 6, 2018
  20. pablofg1978
    Spanish POC Assistant Head Moderator Jun 6, 2018
