175
  1. G_Shoobz_(Brian_Shub)_CW Eclair Jun 13, 2018
    G_Shoobz_(Brian_Shub)_CW, Jun 13, 2018 :
    Am I the only one who's battery is discharging significantly faster after the latest oxygen update? It feels like my phone lasted longer prior to the update.
    cozzmat and OnePlusKathir like this.
  2. E1527104497048 Cupcake Jun 13, 2018
    E1527104497048, Jun 13, 2018 :
    battery is draining more than usual after latest update . are others facing the same issue . any resolution ? sharing screen shot after a full racharge and drain under normal day use . screen on time is less than 4 hours now, earlier it was around 6 hours .
  3. WarGod1842 Honeycomb Jun 13, 2018
    WarGod1842, Jun 13, 2018 :
    check reply#3027
    E1527104497048 likes this.
  4. Q1527321878950 Cupcake Jun 13, 2018
  5. ghostofcain Lollipop Jun 13, 2018
    ghostofcain, Jun 13, 2018 :
    And your phone is still 2°C below ambient temperature, not too shoddy at all.
    Ignoring that the update has, alledgely, been pulled, you should give the phone at least 3-4 update cycles after an update to settle before drawing any firm conclusions on battery life.
  6. WarGod1842 Honeycomb Jun 13, 2018
    lol [e]1f602[/e][e]1f602[/e]
  7. WarGod1842 Honeycomb Jun 13, 2018
  8. Aldokio Donut Jun 13, 2018
  9. pablofg1978 Spanish POC Assistant Head Moderator Jun 13, 2018
    pablofg1978, Jun 13, 2018 :
    Thread merged
  10. siddharth740 Froyo Jun 13, 2018
  11. siddharth740 Froyo Jun 13, 2018
    siddharth740, Jun 13, 2018 :
    I haven't Used Wifi still It uses Battery
    And It Is Heating From Back In less usage also still i m not playing game ryt now in normal usage its heating from back.
  12. RaskinEric Cupcake Jun 13, 2018
    siddharth740 likes this.
  13. cozzmat Honeycomb Jun 13, 2018
    cozzmat, Jun 13, 2018 :
    is more or less the same...maybe a little bit worse than before..but not so significant in my case!
  14. pablofg1978 Spanish POC Assistant Head Moderator Jun 13, 2018
    Thread merged
  15. Stako187 Cupcake Jun 13, 2018
    Stako187, Jun 13, 2018 :
    Hmm i have 5t also and i can say it heats up like a MF.... Its getting so hot its unpleasant to play in one point. And drain battery like nuts(like 2.5sot most).. If anyone has solutions pls share (its geting verry hot - no case just with screen prott.
    Ps Thats fot PUBG no mater is it on highest graphics or not it heats uo on lower also.
  16. E1527104497048 Cupcake Jun 13, 2018
    any reason for Google play services using almost 16 % battery?
  17. Atharvmanwaniii Froyo Jun 13, 2018
    Atharvmanwaniii, Jun 13, 2018 :
    I use no case with a screen protector too but my phone works just fine. decent battery with minimal if no heating. phone gets a little warm to the touch but it's hardly even noticeable. I dunno what might be wrong with your one
  18. WarGod1842 Honeycomb Jun 13, 2018
    you must've updated apps/ Google play is scanning apps in the background. Or a game is running in background.
  19. pablofg1978 Spanish POC Assistant Head Moderator Jun 13, 2018
    Thread merged
  20. E1527104497048 Cupcake Jun 13, 2018
    thanks for the reply . I did steps in your post #3027. let me check tomorrow . will update you with the screenshot .
    WarGod1842 likes this.
