238
  1. G_Shankar_Regumudi
    Donut Jun 21, 2018
  2. Royston Kandhare
    Cupcake Jun 21, 2018
    Royston Kandhare , Jun 21, 2018 :
    My phone keeps making the volume less/lower when headphones are on.. and this has started after the update which rolled on my phone yesterday!! using Oneplus6
  3. Royston Kandhare
  4. Sandeepp1308
    Froyo Jun 21, 2018
    Sandeepp1308 , Jun 21, 2018 :
    yes as far as I have seen with my usage 5.1.6 I used to get a better screen on time up to 7hrs
    but after the 5.1.8 I just get up to 5hrs -6hrs that's like a little less but way better than other phones
    OPOBEAST likes this.
  5. Gav_W86
    Starting Point Expert Community Expert Jun 21, 2018
  6. N1529128997941
    Eclair Jun 21, 2018
  7. Majuran thas
    Honeycomb Jun 21, 2018
    Majuran thas , Jun 21, 2018 :
    it is normal dude........
    it may cool after 80%
  8. U1527925755176
    Donut Jun 21, 2018
    U1527925755176 , Jun 21, 2018 :
    sry but it is not normal because it's getting heated extensively than usual after the update. heating issue has increased after the upsate
  9. Bhanusai
    Donut Jun 21, 2018
    Bhanusai , Jun 21, 2018 :
    did you tried by removing back case?
  10. Majuran thas
    ah really?
    I didn't notice it yet bro....
    dear OnePlus,
    please fix it all asap.... please
  11. N1529128997941
    Eclair Jun 21, 2018
  12. Bhanusai
    Donut Jun 21, 2018
    when you don't know the cause ,you need to try every thing
  13. N1529128997941
    Eclair Jun 21, 2018
  14. Aa.mamgain
    Aa.mamgain , Jun 21, 2018 :
    Phone idle battery drain is too much, didn't expected that from a stock Android phone.
  15. Deactivated User
    Jun 21, 2018
  16. V1527790894947
  17. O1512759463289
    Eclair Jun 21, 2018
  18. Aa.mamgain
    how can I check what all apps are running on background?
  19. serafica.josh
    Eclair Jun 21, 2018
    serafica.josh , Jun 21, 2018 :
    I'm having the same problem with battery drain going fast and alarming when others don't have any problems with the latest update. Is there anything that might be done about this?
  20. Blue_Blurr
    Eclair Jun 21, 2018
    Blue_Blurr , Jun 21, 2018 :
    You still use the same red cable, correct? Just not the dash chrager block?
