200
  1. Lucky M. Nelson
    Froyo Jun 21, 2018
    Lucky M. Nelson , Jun 21, 2018 :
    I've noticed that my OP6 turns really hot when browsing my Google Photos. Why could this be? This doesn't happen to my Galaxy S8 when doing the same task...
  2. H1528014194708
    Donut Jun 22, 2018
  3. H1528014194708
    Donut Jun 22, 2018
  4. N1529128997941
    Eclair Jun 22, 2018
  5. pablofg1978
    Spanish POC Assistant Head Moderator Jun 22, 2018
    pablofg1978 , Jun 22, 2018 :
    Threads merged
  6. Vamsi.karthik
    Froyo Jun 22, 2018
    Vamsi.karthik , Jun 22, 2018 :
    why is my phone awake while my screen is off???
    I think that might be the case for drain in my battery
  7. Deactivated User
    Jun 22, 2018
  8. Vamsi.karthik
    Froyo Jun 22, 2018
    but that doesn't take up whole of battery in the night right ? in all phones
    that too like 17 percent
  9. M1528042880961
    Eclair Jun 22, 2018
    M1528042880961 , Jun 22, 2018 :
    issue is battery draining while in idle mode not the apps which r awakening or so op team should fix this bcoz why would be pay 35 - 40 k
  10. asiriw
    Donut Jun 22, 2018
  11. Deactivated User
    Jun 22, 2018
  12. Deactivated User
    Jun 22, 2018
  13. the_o2
    User of the Year 2018 Jun 22, 2018
    the_o2 , Jun 22, 2018 :
    Might be you watching some hot pics ..;)
    Force stop the app and clear the cache and data and uninstall the updates and restart your phone, then update it latest from play store..
  14. pablofg1978
    Merged
  15. Guptaprashant19
    Cupcake Jun 22, 2018
    Guptaprashant19 , Jun 22, 2018 :
    yes correct.
    I use the same red cable with different charge block of low voltage
    Blue_Blurr likes this.
  16. Kartik chowdary
    Eclair Jun 22, 2018
    Kartik chowdary , Jun 22, 2018 :
    My One Plus 6 Battery lasts for only 7hrs ..
    I play games for 30 min only ....
    One Plus, i am not satisfied with the Battery and the portrait mode is average.. Please fix this .....
  17. U1513149367412
    Honeycomb Jun 22, 2018
    U1513149367412 , Jun 22, 2018 :
    After doing the OS update to 5.1.8 , I am facing tremendous amount of battery drain. last time when I checked at night the battery percentage was 26% but in the morning it was completely swtiched off with 0% of battery. How many of you facing this issue? I am thinking of rolling back to 5.1.6 version
  18. G_Chris_CazRoch_IdPx
    Donut Jun 22, 2018
  19. abovethelimit
    abovethelimit , Jun 22, 2018 :
    none here either. I did notice few apps draining the battery post the update and have chosen to delete and replace them with similar apps.
  20. mojoyoyo77
    Lollipop Senior Moderator Jun 22, 2018
    mojoyoyo77 , Jun 22, 2018 :
    This is not normal, in this construction the battery is still quite good. Surely some application is causing the problem, check that now, after the boot, if it has been normalized. If not, investigate, to find out which is the application that is draining your battery.
    K_Anand_kiran_kumar likes this.
