196
  1. arghya1990
    Cupcake Jun 24, 2018
    arghya1990 , Jun 24, 2018 :
    Just Wanna Share My SOT! I'm happy what I'm getting at the moment! The thing is I didn't update my OP6 to the Latest 5.1.8 Version after all these negetive Responses. I'm on 5.1.6!
    VamanP and Ganjinagaraju_one like this.
  2. Ganjinagaraju_one
    Ganjinagaraju_one , Jun 24, 2018 :
    yup... it's better to stay some days on old versions... else bugs will play with us...
    arghya1990 likes this.
  3. arghya1990
    Yes! I always prefer to do that!
  4. VamanP
    VamanP , Jun 24, 2018 :
    Lucky you mate! My OnePlus 6's battery life took a hit after the update :(
  5. arghya1990
    Actually the thing is everyone became way too much exited to update their phone.. But I think we should take it slow! Let's read some reviews or post usage comments first.. That way these problems can be avoided! But don't worry OP devs are seriously responsive and I'm sure they are working on this issue!
    VamanP likes this.
  6. Madesh88
    Madesh88 , Jun 24, 2018 :
    after updating 5.1.8 oxygen os .. lot of issues like tempertaure increase & battery draining quickly ..
    iamsarandev likes this.
  7. camohan
    Marshmallow Moderator Jun 24, 2018
    camohan , Jun 24, 2018 :
    Sorry but if you want to help yourself and others pls provide with some statistics, battery graphs, apps you use, logs.
    There are so many threads without any relevant information.
  8. Z1528539040455
  9. iamsarandev
    Abinantha likes this.
  10. pablofg1978
    Spanish POC Assistant Head Moderator Jun 24, 2018
    pablofg1978 , Jun 24, 2018 :
    Merged
  11. Madesh88
  12. Madesh88
  13. Muhammad Aadil Warsi
    Muhammad Aadil Warsi , Jun 24, 2018 :
    As compare to old os (5.1.6) latest os version (5.1.8) is draining battery. I'm the only one who is suffering or other are suffering too ?? Is any solution for this or It will solve after upcoming update ?
    Thanks you !!
  14. Deactivated User
    Jun 24, 2018
  15. pablofg1978
    Merged
  16. Abinantha
    Abinantha , Jun 24, 2018 :
    it's all because of the latest update! it was fine before that
  17. Y1529855639521
    Y1529855639521 , Jun 24, 2018 :
    my device is getting heat up very frequently also while making videos. Is this happening with others also?
  18. Gamiansavage
    Gamiansavage , Jun 24, 2018 :
    there is a temporary fix. Just switch off the ambient display thing.. Let me know if it works. Kinda worked for me. I'll keep updating. upvote this! Cheers
  19. serafica.josh
    Eclair Jun 24, 2018
  20. Aays
    Eclair Jun 24, 2018
    Aays , Jun 24, 2018 :
    I turned it off about half an hour ago and it seems like it did help. I'll test it for a couple of days and see if it helps but as of now I think that you got it! The only bad thing is that I like the ambient display but if i like the batterytime even more :)
