228
  1. F1529898231964
    Cupcake Jun 25, 2018
  2. mahendrakumar350
    mahendrakumar350 , Jun 25, 2018 :
    i think.....who updated their OP 6 -A6000 oxygen 5.1.7 along with 5.1.8 oxygen through vpn especially indian variant and other region device's .they're facing this battery draining and heating issues
  3. TheMystic
    Lollipop Jun 25, 2018
    TheMystic , Jun 25, 2018 :
    there is no need for that. in fact, he shouldn't do that.
    the full ROM should be downloaded from the official website and flashed from recovery.
  4. TheMystic
    download the full ROM from OnePlus website and flash it via recovery. wipe system cache from recovery before flashing it.
  5. Elatchian Veeramani
    Honeycomb Jun 25, 2018
    Elatchian Veeramani , Jun 25, 2018 :
    Yes This is working Guys. Give a try. You can feel a difference. Speaker Base is back, Battery drains Normally. Face lock lightning.
  6. Prcko
    KitKat Jun 25, 2018
    Prcko , Jun 25, 2018 :
    flash via recovery I don't believe
  7. Elatchian Veeramani
    No need to flash. Just install via local upgrade in system updates
    gaurav.malhotra likes this.
  8. TheMystic
    what is there to not believe? it is a simple way to solve the problem. it won't damage your device or cause any data loss.
  9. Prcko
    KitKat Jun 25, 2018
    I know [e]1f609[/e]
  10. Hydra Bob
    Marshmallow Jun 25, 2018
    Hydra Bob , Jun 25, 2018 :
    Not available in the stock recovery for the OP6.
    Prcko likes this.
  11. Elatchian Veeramani
  12. Prcko
    KitKat Jun 25, 2018
    if you have oneplus 6 you can't flash via recovery
  13. TheMystic
    you mean you can't flash the ROM via recovery?
  14. TheMystic
    what exactly is the purpose of stock recovery then?
  15. Hydra Bob
    Correct. The options for install from internal storage and adb sideload are missing from the stock recovery. Supposedly something to do with the A/B partition scheme. Hopefully they add them back in the future because not everyone wants to install TWRP.
  16. Prcko
    KitKat Jun 25, 2018
    now is different you can wipe cache or make a factory reset. but can't flash firmware because Google project treble.
  17. TheMystic
    quite strange they would do something like that. I thought they would add the option to do a nandroid backup. instead they removed the option to install the official ROM even.
    Hydra Bob likes this.
  18. Avicity
    Avicity , Jun 25, 2018 :
    Root directory means put the file where all the folders are and make sure it's not in a folder
  19. K1529935547930
  20. Elatchian Veeramani
