228
  1. izzykasha
    Lollipop Jun 25, 2018
    izzykasha , Jun 25, 2018 :
    more importantly hoping for a Ronaldo hattrick tonight??
    J1514446017986 likes this.
  2. gaurav.malhotra
    Honeycomb Jun 25, 2018
    gaurav.malhotra , Jun 25, 2018 :
    you don't need the laptop/computer.
    check the thread post again, I have updated the steps.
  3. indersaheb175
    Eclair Jun 25, 2018
    indersaheb175 , Jun 25, 2018 :
    u want us to oper developer option and than oem unlocking .. than after that the process for me is blank. can you help ?
  4. indersaheb175
    Eclair Jun 25, 2018
    i have been experiencing bad sound quality from loud speaker than earlier and grainy pics . but i dont have issues with battery draining .. should i still go for update again ?
  5. mindmaster25
    Donut Jun 25, 2018
    mindmaster25 , Jun 25, 2018 :
    lets see tonight!!!
    izzykasha likes this.
  6. Arpit_Momaya
    Cupcake Jun 25, 2018
  7. valen2384
    valen2384 , Jun 25, 2018 :
    my SOT is 6h 10m. did a full battery drain yesterday testing to see if i had the same issues but 6h is pretty good but I am having Bluetooth issues with the bullets and car Bluetooth when both are connected since the 5.1.8 update.
  8. indersaheb175
    Eclair Jun 25, 2018
    we have to admit that oxygen update lacks quality as compared to stock android . unstable and unreliable. even i am getting problem of speakerphone call while multitasking . had to hang up call once and dail second time after pausing the game or other work i am doing. cant hear voice at first call. so many issues after update.
    Sudhanshu Joshi SDD likes this.
  9. Sudhanshu Joshi SDD
    Sudhanshu Joshi SDD , Jun 25, 2018 :
    but 0m on screen..he is on standby ..
  10. gaurav.malhotra
    who asked you to perform OEM unlocking - no changes in developer option to be done - follow the steps mentioned in main thread.
  11. gaurav.malhotra
    yes on standby 2 - 4% is normal in 6 hrs. In OP6 I have observed this percentage to be bit higher since day 1.
  12. gaurav.malhotra
    I didn't have these issues, hence cannot suggest on it.
  13. V1527867312819
    Donut Jun 25, 2018
  14. Sudhanshu Joshi SDD
    gaurav.malhotra
    yes on standby 2 - 4% is normal in 6 hrs. In OP6 I have observed this percentage to be bit higher since day 1.​
    yes right he is getting good back up..but i don't think it will be same as soon as he start using it.. actually even if you put your phone on battery saving mode battery drop at same rate i tried this. I am facing drain issue while using phone normally say 1% drop in 2 minute
  15. Sudhanshu Joshi SDD
    so basically i am getting 6 hr of on screen time..and yes its very bad..and this is with just 1 mnth old phone... imagine after 5-6 mnth
  16. valen2384
    so, are you saying 6 hours SOT not good or that its just the bare minimum?
    has anyone gotten more then 6hours SOT since update?
  17. MarianneScheepers
  18. R1529952566079
  19. sushantsutar18
    Eclair Jun 25, 2018
  20. tusharshahsp
    Donut Jun 25, 2018
