213
  1. GULAM GOUSE
    Cupcake Jun 26, 2018
    GULAM GOUSE , Jun 26, 2018 :
    Hi Oneplus team,
    I am getting heavy battery draining problem after oxygen 5.1.8. Please help with some resolution.
    Please help.
    RAJESHPRIYADARSHI likes this.
  2. pablofg1978
    Nougat Head Moderator Jun 26, 2018
    pablofg1978 , Jun 26, 2018 :
    Merged
  3. BrightHulk
    BrightHulk , Jun 26, 2018 :
    Wait till next update. Hope OnePlus fixes it out, most of users face problem of battery drainage.[e]1f44d[/e][e]1f44d[/e]
  4. pablofg1978
    Merged
  5. Attano_26
    Froyo Jun 26, 2018
    Attano_26 , Jun 26, 2018 :
    battery drains a lot after the oxygen 5.1.8 update...
    and also the face recognition it doesn't always emit the light from the screen when in low light...
    phots are getting blurred when zoomed in...
  6. nakku.1993
    nakku.1993 , Jun 26, 2018 :
    facing similar problem with battery..in the night my phone lost around 15% battery..when i was sleeping n my phone was too.
    sayem991 and Attano_26 like this.
  7. Vishesh Mehta
    Vishesh Mehta , Jun 26, 2018 :
    android os n system taking together almost 14%of battery
    and when phone idle also about 8%battery used!!!
  8. G_Karthikeyan_Mohanasund
    G_Karthikeyan_Mohanasund , Jun 26, 2018 :
    It is been few days since battery getting stabilized.only change I've done is enabled adaptive brightness.Earlier prior to that used to adjust brightness manually.Very happy with my 6.
  9. G_gaganpreet_singh
    Gingerbread Jun 26, 2018
    G_gaganpreet_singh , Jun 26, 2018 :
    there might be some background apps or activities that are killing his battery it's completely normal
  10. D1517844581455
    Honeycomb Jun 26, 2018
    D1517844581455 , Jun 26, 2018 :
    I tried installing the update locally, and it seems to have worked. overnight battery drain has improved and so has the overall battery life. now that I have installed the update, do I need to keep the downloaded file on my device or is it ok if I delete it now??
    gaurav.malhotra likes this.
  11. gaurav.malhotra
    gaurav.malhotra , Jun 26, 2018 :
    you need to give couple of charge cycles for it to stabilize, first 5 percent of battery drop is always quick hence cannot judge overall battery in just 2% drop.
  12. big H
    big H , Jun 26, 2018 :
    seems to have improved as I charged bit for another fifteenth mins then reboot
  13. gaurav.malhotra
    you can delete it.
  14. D1517844581455
  15. gaurav.malhotra
    you seem to be in poor network zone and that will also consume lot of Battery.
    give it couple of charge cycles and observe if overall battery stays longer.
  16. gaurav.malhotra
    how does that matter on how I found the solution? did the solution work for you?
  17. gaurav.malhotra
  18. gaurav.malhotra
    reinstall 5.1.8 and you will get best of battery life after 2 charge cycles.
  19. gaurav.malhotra
    big H likes this.
  20. Ronakkar
    Ronakkar , Jun 26, 2018 :
    how can i reinstall it
