208
  1. Athulpk
    Cupcake Jun 26, 2018
  2. Madhukiran_25
    Madhukiran_25 , Jun 26, 2018 :
    Battery is getting heated just after 20mins of charge in my OP6.
    This problem has occurred after latest update.
    I didn't had any problem before the update.
  3. Attano_26
    Froyo Jun 26, 2018
  4. G_jonny_cool_nxOr
    Jelly Bean Jun 26, 2018
  5. Attano_26
    Froyo Jun 26, 2018
    Attano_26 , Jun 26, 2018 :
    I did not no reply
  6. MeghSinghFouzdar
    Attano_26 likes this.
  7. O1527788690851
  8. U1513149367412
    Honeycomb Jun 26, 2018
    U1513149367412 , Jun 26, 2018 :
    so I can see some slight changes in battery backup though not significantly but pleasant enough to use the phone...let me how it performs after second cycle of recharge
  9. MasterSwami
    Ice Cream Sandwich Jun 26, 2018
  10. F_Martin_Jakobsen_eRgY
    F_Martin_Jakobsen_eRgY , Jun 26, 2018 :
    IT has nothing to with a rooted phone !
    Root is parent directory of Storage.
    So you need to navigate backwards to find it. Most of the File Managers will not show you the root directory due to security reasons but if you want you can use the File Manager app from playstore
  11. G_Uttam_Kumar_KPac
  12. R1529476248463
  13. F_AashIsh_M_PandEy_pnnq
    Eclair Jun 26, 2018
    F_AashIsh_M_PandEy_pnnq , Jun 26, 2018 :
    facing the same problem
    and after ota update 5.1.8 battery charging time is also more earlier my op6 takes 1 hour 27 minutes from 15 to 100% now it takes almost 1 hour 52 minutes from 15 to 100%
    anyone else facing this kind of problem?
    dr_anup and M1529842723287 like this.
  14. Attano_26
    Froyo Jun 26, 2018
    ha Mee tooo....
  15. Attano_26
    Froyo Jun 26, 2018
  16. racaldero
    Donut Jun 26, 2018
  17. E1529996549211
    E1529996549211 , Jun 26, 2018 :
    I've been having battery issues with my 3T 5.0.8
    Completed a factory reset and this seems to have solved the issue.
    I have heard if you have a lot of apps installed this can cause problems with updates
  18. Medxion007
    Donut Jun 26, 2018
  19. Attano_26
    Froyo Jun 26, 2018
    just enter the battery options in settings and u can see the % of battery consumption of every app...
  20. F_AashIsh_M_PandEy_pnnq
    Eclair Jun 26, 2018
    go to settings tap on battery and see which applications consuming more battery
