200
  1. D1530174855025
    Cupcake Jun 28, 2018
    D1530174855025 , Jun 28, 2018 :
    hmm, i got 9 hours: wifi, gps, nfc , bluetooth always on. Usage: youtube, 1 pubg game, camera about 20 min, bluetooth music, telegram/instagram. dk why ure oneplus discharge quickly. How do u use it?
  2. Satyapal_Bharati
  3. Ninja_Toru
    Froyo Jun 28, 2018
    Ninja_Toru , Jun 28, 2018 :
    i appreciate your help. btw i am running lineage os on my other phone. the question was to get familiar with OnePlus's process.
  4. SnHL8506
    SnHL8506 , Jun 28, 2018 :
    have you try doing a system cache wipe? I was having battery drainage issue after the update. found a thread that suggested doing a cache wipe, which worked. now I can get almost a day's worth of usage.
  5. Daan_Eekhofアニメ
    Jelly Bean Jun 28, 2018
    Daan_Eekhofアニメ , Jun 28, 2018 :
    5.1.8 has been reported to drain battery a lot quicker than usual. You can try the following:
    1. Check if Cellular signal strength wasn't bad (orange/yellow color) this usually results in a quicker drainage.
    2. Wipe cache from recovery.
    3. Turn off location and/ or Mobile Data when in range of WiFi to reduce drainage.
    4. Heard "dirty flashing"* 5.1.8 and wiping cache after fixes it as well for some people.
    *Basically reinstalling the update without wiping user data e.g. apps and stuff....
  6. Manju@1+6
  7. Mohit32
  8. Kushsharma1991
    Kushsharma1991 , Jun 28, 2018 :
    I am having the same issue with OP6 as the battery is draining very fast after latest OS update and the phone is also fetting heated while xonnexting for charge..
  9. A1526990124561
  10. Dhruvrawal
    Froyo Jun 28, 2018
    Dhruvrawal , Jun 28, 2018 :
    I am using OnePlus 6 since 25th June but I am experiencing that battery is draining very fast
  11. Darg1702
    Eclair Jun 28, 2018
    Darg1702 , Jun 28, 2018 :
    I'm experiencing a HUGE drain since last update. Could it be better if I delete some apps in order to reduce background activities? From the battery monitoring page it looks like I have 2 or 3 apps draining 1%..most likely it won't even barely solve the problem
  12. A1526990124561
    A1526990124561 , Jun 28, 2018 :
    I don't know what's happening. My phone suddenly drained upto 40 percent in 30 mins (whilst playing PUBG). I know the game is pretty heavy and intensive, but 40 percent in 30 mins is pushing it.
    BTW I didn't have this problem before the update
    and what is the point of the dash charger if it drains as quickly as it charges.
    This issue really has to be fixed ASAP
    P1529809007779 likes this.
  13. E1529330452133
    Donut Jun 28, 2018
    E1529330452133 , Jun 28, 2018 :
    bro use dark theme and fingerprint unlock and disable data connection , wifi , gps if not in use and put the brightness in low after that Go to settings - battery option click on battery optimization on the right top corner 3 dots there click on that and enable advanced battery optimization . Then go to sounds & vibration disble touch sounds , dail pad tones , screen locking sounds , vibration on tap , also vibration for call . Dont use gestures and also if ur using data connection with a low range the battery may drains quickly. update the software to latest
    Manoj_Prakash_B_ likes this.
  14. Terryruiz
    Ice Cream Sandwich Jun 28, 2018
    Terryruiz , Jun 28, 2018 :
    you forgot to say turn off phone to save battery lol
  15. E1529330452133
    Donut Jun 28, 2018
    [e]1f602[/e][e]1f602[/e][e]1f602[/e][e]1f602[/e]
  16. Parth goyal970
  17. Darg1702
    Eclair Jun 28, 2018
    certainly you should check in normal usage, not while playing high demanding games, but the issue is there and that's for sure. And that's a shame because I don't want to starve for a plug every 5 or 6 hours.
  18. G_Parth_Gandhi_KIci
    Eclair Jun 28, 2018
    Ronakkar and Sc1ence_G like this.
  19. anandadeppa
  20. C1528537722928
