206
  1. V1530989779038
    Cupcake Jul 7, 2018
    V1530989779038 , Jul 7, 2018 :
    yes right.
    Z1528253389790 likes this.
  2. sakettekas
    Eclair Jul 7, 2018
  3. Z1527536839759
    Donut Jul 7, 2018
    omkarbhagat likes this.
  4. unity13
    Cupcake Jul 7, 2018
    unity13 , Jul 7, 2018 :
    even iam facing the same problem..ma phone was good at begining when I unboxed it..after the update 5.1.8 battery isn't lasting long
    Z1528253389790, caiwen88 and NateDev like this.
  5. Deactivated User
    Jul 7, 2018
  6. Deactivated User
    Jul 7, 2018
  7. San2Sreshta
    Gingerbread Jul 7, 2018
    San2Sreshta , Jul 7, 2018 :
    improved after clearing the cache.
    7 hours of SOT, still 25 percentage of battery Happy with OnePlus 6 results after 30 months of OnePlus X [e]1f604[/e]
  8. OPOBEAST
    Honeycomb Jul 7, 2018
    OPOBEAST , Jul 7, 2018 :
    Guys do you think charging from 30% to 88% in 50 minutes is too slow? I feel like it should be faster.
  9. asaputrosnk
    Gingerbread Jul 8, 2018
  10. R1529590174739
    Donut Jul 8, 2018
    R1529590174739 , Jul 8, 2018 :
    Can u suggest how to charge the battery in a daily routine
  11. R1529590174739
    Donut Jul 8, 2018
  12. Kartik chowdary
    Froyo Jul 8, 2018
    Kartik chowdary , Jul 8, 2018 :
    Really battery has been worse in One Plus. 6..
    I feel OnePlus 5T was bit better than OnePlus 6 in terms of battery...
    Portrait mode is also average..
    One plus please fix this immediately...
    Look before 5.1.8 update ,i used to get more than 8hrs..
    Now after update,i am getting not more than 6hrs..
    One plus please fix this in the next update.....
    OPOBEAST likes this.
  13. Yoglalge
    Eclair Jul 8, 2018
    Yoglalge , Jul 8, 2018 :
    i would suggest you to calibrate battery life by 0-100 charging once a month at max...and use greenify ,which stops all the unecessary apps before charging your phone. Rest all depends on how safe your socket and conditions.never plug it in a bad socket
  14. W1528885365600
  15. Jack_Sparrow_
    Eclair Jul 8, 2018
    Jack_Sparrow_ , Jul 8, 2018 :
    My main problem is that phone looses signal very often and wake up during stand by to hunt signal. When network is ok, battery is ok too, not like 5.1.5, but it's ok.
  16. Prcko
    KitKat Jul 8, 2018
    Prcko , Jul 8, 2018 :
    so it isn't battery problem it's network problem. before update your network signal was ok?
  17. Jack_Sparrow_
    Eclair Jul 8, 2018
    Prcko
    so it isn't battery problem it's network problem. before update your network signal was ok?​
    I don't remember how signal was before this update, but battery seemed to last longer (in same conditions I mean).
  18. Prcko
    KitKat Jul 8, 2018
    now you have a better signal so wait for result of battery life
  19. Jack_Sparrow_
    Eclair Jul 8, 2018
    I don't need that [e]1f609[/e], I understood that main problem is probably network hunt. I hope that next update will fix this
    theAlok likes this.
  20. Shshank Vishwa
    Honeycomb Jul 8, 2018
    theAlok likes this.
