196
  1. kumaryashwin
    Jelly Bean May 22, 2018
    #41
  2. jitu11
    Cupcake May 22, 2018
    #42
  3. CYB3R0ID694
    Gingerbread May 22, 2018
    CYB3R0ID694 , May 22, 2018 :
    Do this..
    Drain batter completely then Full charge it while switched off..
    PS. I'm facing same issue...
    #43
    ASSAiL.J179 and K1528778038086 like this.
  4. jitu11
    jitu11 , May 22, 2018 :
    CYB3R0ID694
    Do this..
    PS. I'm facing same issue...​
    read somewhere it may happen while device running initial setup, but never faced such issue with Mi
    #44
    Damonp87, cereal_kllr and CYB3R0ID694 like this.
  5. Anurag_Shrivastav
    Eclair May 22, 2018
    #45
  6. CYB3R0ID694
    yeah... initial setup use lot of services..
    #46
    Sachifus and ghostofcain like this.
  7. drpramodjangid
    drpramodjangid , May 22, 2018 :
    i also got today OnePlus 6 128 mirror black, i charged it fully and use for 4 to 5 hours but this issue is not created by phone..
    #47
  8. Feskprins
    Eclair May 22, 2018
    Feskprins , May 22, 2018 :
    Yeah, this is normal the first time you use it. Don't worry, it will go away when you start using it regularly.
    #48
    P1534647030139 and ghostofcain like this.
  9. ghostofcain
    Marshmallow May 22, 2018
    ghostofcain , May 22, 2018 :
    That is well within the normal operating temperature of SD845. What was the ambient temperature at the time of the reading?
    As for the battery, you got a new toy this morning it's barely left your hands and you've spent a lot of time setting it up and the battery life is below expectations? No shit Sherlock, give it a while to settle down.
    #49
  10. Feskprins
    Eclair May 22, 2018
    Thing is too, that the main reason a battery deteriorates is due to heat. Since the phone doesn't get overly hot while fast charging thanks to the dash charger compared to other fast charging options, the battery remains healthy. The temp you posted is absolutely fine.
    #50
  11. momokuvu
    momokuvu , May 22, 2018 :
    I am not facing any issues. I played PUBG and my OP6 didnt heat as well battery is working superb. I think you should replace your phone if u have option to replace it.
    #51
    cereal_kllr likes this.
  12. love1plus1specs
    #52
  13. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer May 22, 2018
    NeVeR_SeTTLe , May 22, 2018 :
    What are your temperatures? Did you measure it with CPU-Z?
    #53
  14. sarathymmm
    #54
  15. posco
    Donut May 22, 2018
    posco , May 22, 2018 :
    I think it's mostly normal as you must have used to continuously cos it's a new phone and then setting up also put a bit of pressure on the processor. Once the phone settles down it'll be fine.
    #55
  16. pablofg1978
    Spanish POC Assistant Head Moderator May 22, 2018
    pablofg1978 , May 22, 2018 :
    Threads merged
    #56
    cavtab likes this.
  17. djarish
    djarish , May 22, 2018 :
    Same problem with me
    #57
  18. djarish
    Screenshots of thermal When I was using one plus switch... Even one plus switch was not able to transfer music and videos.. Then I used '' clone it'' to transfer them
    #58
  19. ghostofcain
    You wanted speed and latest SOC, and now you're complaining it generates heat!
    #59
    Damonp87, NateDev and Terryruiz like this.
  20. ghostofcain
    #60
    NateDev likes this.
