200
  1. Waterpas
    Cupcake Jul 10, 2018
    Waterpas , Jul 10, 2018 :
    I have the a6003. I will post stats when I have info from accubattery. And yes tinder is installed. But it a normal developed app. Not some shady dating app floating around in the playstore
  2. superplus
    English POC Assistant Head Moderator Jul 10, 2018
    pablofg1978 and agoinfly like this.
  3. fahad2mail
    Froyo Jul 10, 2018
    fahad2mail , Jul 10, 2018 :
    Model A6000
    OOS 5.1.8
    i am facing heating issue with my 2 favorite game after i bought oneplus 6 3 days ago.
    mobile legends bang bang and pubg.
    mlbb i cant even play on high settings.
    i need to select medium settings and also need to turn off high frame rate option. otherwise it heats up pretty quickly and the frame drops so much that it id unplayable.
    in pubg the heating issue wont ruin my gameplay, i play hdr with high settings.
    but the device gets hotter and i need to stop playing after 30 mins of gameplay.
    i am using stock cover and official tempered glass.
    is that normal?
    babasaheb khandare likes this.
  4. Elaitscha
    Eclair Jul 10, 2018
    Elaitscha , Jul 10, 2018 :
    Is this a new update? I have to look if I get it, do I get it through the manuel updater? So the version 5.1.18 ? ..not 5.1.8 due to battery problems
  5. Chinmay_Bandiwadekar
    Donut Jul 10, 2018
    Chinmay_Bandiwadekar , Jul 10, 2018 :
    I also observed same thing while playing PUBG.
    it seems PUBG is not yet optimised...as it is just release in March...hence this heating issue..
    future updates to the game should improve the situation...
  6. fahad2mail
    Froyo Jul 10, 2018
    so its not oneplus 6 problem. Rather than sd845 optimization problem right?
  7. DARTH 007
    KitKat Jul 10, 2018
    DARTH 007 , Jul 10, 2018 :
    it's bcos the latest update sucks.
    Justinnov23 likes this.
  8. babasaheb khandare
  9. Chinmay_Bandiwadekar
    Donut Jul 10, 2018
  10. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Jul 10, 2018
    NeVeR_SeTTLe , Jul 10, 2018 :
    If you play games, of course it will get heated slightly.
    Those games are intensive.
    Kytharsis likes this.
  11. SoHaaNRaj
    SoHaaNRaj , Jul 10, 2018 :
    Yes, A6000 has issues with battery life but A6003 doesn't.
    That is where we conclude.
    Indian variant is way more cheap and vulnerable rather than A6003.
    Shit Man Shit!
    **** OnePlus India.
  12. baruah.amlan
    Donut Jul 10, 2018
    Sc1ence_G likes this.
  13. Dobger24
    Dobger24 , Jul 10, 2018 :
    Hey. U wanted a cheaper alternative. Still a good phone. Also turn off notch display. that works on battery too
  14. xbonnaire
    Eclair Jul 10, 2018
    xbonnaire , Jul 10, 2018 :
    I agree with you, but do not panic. Oneplus is usually very reactive with all these kind of issues and I hope this can be solved with only a software update. However I can imagine your frustration
  15. Dodkrake
    Ice Cream Sandwich Jul 10, 2018
    Dodkrake , Jul 10, 2018 :
    Sorry, I meant 5.1.8. I don't have battery drain issues and some of this usage has been with the brightness at max
  16. Nikhil Seenivas
    Honeycomb Jul 10, 2018
    Nikhil Seenivas , Jul 10, 2018 :
    i would advise not to turn off notch.
    but sure go ahead if you would like burn in
  17. Elaitscha
    Eclair Jul 10, 2018
  18. Elaitscha
    Eclair Jul 10, 2018
    No problem man! :D Thx. But when do you think comes 5.1.10 / 9 for oxygen?
  19. Dodkrake
    No idea honestly.
  20. G_Shankar_Regumudi
    Donut Jul 10, 2018
